Is there any way to track each assigned task in percentage?
rutu.purohit November 22, 2022
Hi, as I am exploring more and working with JIRA, I have been facing this challenge to keep a track of progress of each task after the work begins.
Normally a spreadsheet is maintained to record completion in percentage on a different platform. But it would be great if we can integrate that. Is there any tool available that can do the same in JIRA?
Karim ABO HASHISH
November 22, 2022
hi @rutu.purohit
You can use the original estimate and time tracking fields to have such functionality.
Check the below example
  1.  In the below ticket I've set 10 days for the original estimate and logged 2 days which means that the completion percentage is 20%
  2. Now we will create a Kanban board and go to the board settings
  3.  From the card layout, you will find the completion percentage as below, select it and add it to the card from the add button.
  4. Go back to the board and you will find that it's represented in the board as below.
  5. You can also add the same field in the search view as shown below to have an excel-like view.
Pro-Tip When you set the original estimate for the first time, it will reflect in the Time Tracking remaining estimate but if you modify it later, it will not reflect, and you will have to modify the remaining estimate manually
Karim
Hey @Karim ABO HASHISH
This is great. Thanks a lot for your guidance and tips.
Like Karim ABO HASHISH likes this
Karim ABO HASHISH
November 22, 2022
You are most welcomed @rutu.purohit
Like rutu.purohit likes this
rutu.purohit November 23, 2022
@Karim ABO HASHISH Also, is there a way to undo or rectify the logged time ?
Karim ABO HASHISH
November 23, 2022
@rutu.purohit
Here is how can you update or delete a worklog
For Project users, they need to be granted the permissions to log and edit their worklog. Make sure that they have the right permissions. (Check below)
Karim
Got it ! Thanks a lot @Karim ABO HASHISH
Wojciech Wardaszko
November 23, 2022
As much as I like @Karim ABO HASHISH approach, I'd like to offer a different one, more concentrated on what's done and less on how much time of the original estimate has passed.
If you're ok with using a third-party app, I imagine this is possible with most of those that provide checklist functionality.
I know for sure it's possible with our Issue Checklist for Jira (both Free and Pro), which uses a custom field called Checklist Progress %.
Imagine you have a task, and it can be divided into 4 smaller tasks. Instead of creating sub-tasks, you add those as items on your checklist, and then add the "Checklist Progress %" field to your kanban board, so it is displayed on cards.
With this, you can see at a glance how much progress is done regarding each of the tasks.
If you're interested, please take a look at our documentation.
Cheers!
@Wojciech Wardaszko Will look into it. Thanks for your suggestions!
Ersa Aditya Hasdianto October 1, 2024
Hi @Wojciech Wardaszko
thanks for your suggestion, but I have a question here:
if Checklist for Jira app is enabling us to breakdown task without needing to create sub-tasks, then how do we assign each task to different person? because we usually create sub-tasks to do so.
Wojciech Wardaszko
October 2, 2024
@Ersa Aditya Hasdianto
Checklist for Jira supports user mentions inside the checklist items - you can use that feature as assignee, especially since there's an assigned items page and a dashboard gadget "Assigned checklist items".
Checklist for Jira Pro and Enterprise support sending email notifications when someone is mentioned in a checklist item.
I hope this helps. Let me know if you have other questions.
Cheers!
