Hello everyone,
we are currently facing some confusing behaviour in our Jira Cloud:
The action buttons (i.e. Link issue; Create Sub-Taks; Add attachement) within the issue view are hiding behind the "Plus"-Button. These Actions-Buttons were showing as single Buttons directly on top of each issue before.
This somehow gradually affects users individually. Some users still have the buttons listed seperatly on top of the issue view. Other users have these buttons consolidated behind the "+"-Button:
"New" Action-Button View:
"Previous" and preferred Action-Button View:
How is it possible to change the "new" Action-Button View back to the previous configuration?
Thanks for ur help in advance!
Edit: The issue-type (like Bug or Task) does not affect the configuration.
Looks like yet another case of Jira making a completely bad design decision, getting feedback against it, and then completely ignoring the customers and forcing it anyway.
It's amazing how every single Jira update makes the product worse. It's almost as if they're trying to drive people away.
It sounds a lot like https://community.atlassian.com/t5/Jira-questions/Quick-Add-Buttons-now-nested-under-a-new-button-called-quot-Add/qaq-p/2763786
Good that you added the screenshots! I think this is something you need to take up with Atlassian Support. I hope this is some sort of bug or unintended change... or at least something you can choose on global administration level. Can you raise a ticket via https://support.atlassian.com and keep us updated on your progress?
Hey, thanks for the quick response - I've created a support-ticket:
