Issue Detail View
Diane Roberts March 20, 2018
How do I access the Board Settings Issue Detail view to modify this view? When I go to board settings on my project I don't see this tab.
Alexey Matveev
March 20, 2018
Choose the required board. Then go to the board configurations
In the vertical menu you will see the Issue Detail View link
When I go to the board and select board settings this is what I see:
Jack Brickey
March 20, 2018
that is certainly odd. there should be "Issue Detail View" under "Working days". This doesn't appear to be a permissions thing. I'm thinking it may be a conflicting plugin. Was this working before? Is it happening on all boards including Kanbans? Can you check your plugins, disabling them 1-by-1?
MollyJo Tighe
Diane if you're participating in JIRA Labs the Issue Detail View doesn't seem to be available for adjustment. I've just tripped over this myself.
