Hello there!
I've checked the documentation etc but I may not be looking in the right place.
When an Issue is updated I want to perform an API request, is it possible for a listener of some sort to be setup to trigger when an issue is updated?
Any help is appreciated
Hi @Kris Olds
What documentation did you look at, as your tags specify you are using Cloud and Cloud has no listener options like server/DC?
You could create an automation rule based on issue updated as a trigger and then use the action sent webrequest
