Issue export to Excel - Custom Fields
Ravi Bhudiya
July 5, 2016
When exporting issues I currently have two options in relation to Excel:
  • Excel (HTML, All Fields)
  • Excel (HTML, Current Fields)
The first, as the name says, exports all fields which I do not have a need for.
The second misses out on some fields which I require.
Is it possible to define a custom list of fields I'd like to export and have that as a saved option?
Nic Brough -Adaptavist-
July 5, 2016
Add the fields to your issue nvigator display (and save them with the filter too if that might help) - then "current" will include them
Ravi Bhudiya
July 5, 2016
Thanks mate. Much appreciated.
Will Wilson September 6, 2016
What about SLAs?  I added the fields "Time to resolution" and "Time to first response", and they display correctly in JIRA on the list of issues, but when I do "Excel Export CSV", the CSV does not include those two fields.  It is the same for "all" and "current".  Do I need to do something else to get the SLA fields into the CSV?
Register now
