Issue hierarchy on the Plan board
Vladimir Belorusets October 24, 2012
Can we create an issue hierarchy on the Plan board in GreenHopper 6?
Epics are parents of the user stories. I'd like to see the collapsed and expanded tree of epics. Is it possible?
Kinto Soft
October 24, 2012
I don't know wheter this is exactly what you are looking for, but it points in that direction:
Links Hierarchy Structure
Pablo (plug-in author).
Tip: You can group Epics by linking them to the same parent issue. In that way, the plug-in will build the expandable tree of Epics.
Kinto Soft
October 31, 2012
And since the 1.1.0 version, the Links Hierachy Structure plug-in also supports Sub-tasks.
Kinto Soft
December 6, 2012
And since the 1.2.0 version it also supports Epic labels as links.
