Issue in Epic
JiraDev Digital Surf May 27, 2024
Is it possible to add a field (for example Priority) to the issues displayed as Issues of an Epic in the display screens of an issue?
And at the same time is it possible to sort the issues based on this field?
Thanks for your answer.
Michel Neeser
May 27, 2024
Hi @JiraDev Digital Surf
Unfortunately, this is not possible without an additional app/addon. On an epic, the fields shown for children can't be configured out-of-the-box.
However, you can sort the children by certain fields if you use this dropdown:
Hope this helps!
Hannes Obweger - JXL for Jira
Hi @JiraDev Digital Surf,
as already suggested, this isn't currently possible, however if you're open to solutions from the Atlassian Marketplace, you should get pretty close; see e.g. this thread for possible directions forward.
Best, Hannes
FREE
