Issue navigator - hiding colums choice
Magdalena Osys
August 21, 2018 edited
Is there any possibility to hide columns choice in issue navigator for chosen roles? I would like to give permission to JIRA to one of my client, but I don't want him to see and be able to choose "fixed budget" column...Maybe there is another solution, restricted access to advanced issue searching per role? Zrzut ekranu 2018-08-21 o 16.26.42.png
Deleted user August 21, 2018
Hi @Magdalena Osys,
A similar question was answered on the community. Please see the links from Nic's answer.
Jira does not do "field level security". See https://jira.atlassian.com/browse/JRA-1330 for the whole discussion, workarounds, explainations and so on.
Also, jump over to https://marketplace.atlassian.com/23216 for a solution.
Hope this helps
Magdalena Osys
August 21, 2018
Thank you @[deleted]
I am not sure if that's an answer for my problem...I would like to define issue filter for particular role + this role shouldn't be able to change this filter.
To precise, after choosing "Issues and filters" > All issues I would like my client to see only data filtered by my without the possibility of change.
Maybe from a technical point of view that's the same issue?
M.
Register now
