I have used the test file to import into Jira however I have 2 issues: -
1) In the test file there are 3 tests, cake, pie & fruitcake each with 3 test steps. When I import the file I see: -
2 tests both called "fruitcake test" with the test steps from all 3 tests (9 test steps) in the 2 tests and the labels from "fruitcake test".
Is there meant to be a de-limiter that identifies new tests?
We are running Java 8 update 171.
Regards
Frank
Helps if you read the manual! I had set the Discriminator to 'sheet' rather than 'by testcase name change', hey presto it works 😊
