Issue with Boards
Romer Ventura
I found some issues with the Labs Boards for a project. It works with one custom workflow, but not with the other.
The below workflow does not work with Boards:
I get this message:
However, this workflow works perfectly fine. The only difference is the transitions between In Service and Under Maintenance. If i add Prepare for Stock transition outbound from In Service and into Under Maintenance, Boards stop working.
Any ideas? bug?
David Tang
April 28, 2016
This configuration is currently unsupported by the Labs Board, due to having more than 1 transition between the statuses In Service and Under Maintenance. Support for it may arrive in the future. You can view the documentation to see other current limitations.
