Issue with Transitions tab in JIRA
Srilatha Pokala
September 5, 2017 edited
We are currently using JIRA 6.4.10 version;  As per our business process auditing purposes we need extract JIRA Issue transitions information (Ideally who/when/from status to staus information).
Transitions tab NOT showing correct information if JIRA Issue has been moved to same status for several times.
History tab seems to be showing correct status, issue exists only in transitions tab.
Note: Transitions tab added by JIRA Suite Utilities plugin
Any ideas? Any plugins to fix the transitions tab information?
Nic Brough -Adaptavist-
September 5, 2017
What do you think is wrong with the transistions tab?
Srilatha Pokala
Attached document with screenshots for reference.
History tab and Transitions tab does not match.
September 5, 2017
Looks ok to me.  It's counting up the transitions correctly I think.
Srilatha Pokala
counting up the transitions is correct. But it does not give you the exact statuses that issue moved to, as the History tab does.
In Tranistions tab i was expecting to see:
Management Coordinator Review -> Code Development
Code Development -> Management Coordinator Review
Code Development -> Awaiting Code Review Assignment
Awaiting Code Review Assignment-> Code Development
September 5, 2017
Yes it does.  There's 3 Management Coordinator Review to Code Development in the history, 3 in your comment and 3 recorded in the transistions tab.  That is what it is supposed to do - count up the numbers.
Srilatha Pokala
No issue with Execution Times at all, but the order does not look correct.
As i mentioned above, i like to see status to status in each seperate line instead consolidating based on status
September 5, 2017
That's not what the transition tab is for.  It's for reporting on the numbers of executions.
