Issue with automation about summary
Stefano Colagiacomo
January 31, 2024
Hello, I describe the scenario below:
I have a parent task and a lot of subtasks are created via automation
Image the task is named "test - customer name 1"
and subtask is created with subfix -customer name
example:
operation1 -customer name 1
operation2 - customer name 1
operation 3 - customer name 1
etc.
think in the parent task I have to change "customer name 1" to "customer name 2"
I would like to change all the final part, so i would like to keep operation 1,2,3 etc and change only "customer name 1" to "customer name 2"
so this is what I want:
operation1 - customer name 2
operation2 - customer name 2
operation 3 - customer name 3
Mykenna Cepek
January 31, 2024
You'll probably want to use some combination of automation Smart Values for Text fields, to adjust from "...customer name 1" to "...customer name 2". Check out the options in the docs:
https://support.atlassian.com/cloud-automation/docs/jira-smart-values-text-fields/
Part of the complexity here is what the "operationX" text and the "customer name Y" text looks like. For example, if you're sure that neither will ever contain a hyphen, then you can use the hyphen as a delimiter, and use the Smart Value text functions to:
  • Locate the hyphen
  • Keep everything to the left of the hyphen
  • Concatenate the new customer name
