Issues appears in a wrong sprint in kamban
Fabio Manzoni
Hi Guys,
Doubt, I have some issues that were moved to a new sprint because the previous sprint was finalized. But they appear only in the previous sprint in Kamban's view. This in the Cloud. Is there any configuration to solve?
Fabio
Nic Brough -Adaptavist-
March 5, 2018
Um.  Kanban doesn't do sprints.  Do you mean Scrum boards?
Fabio Manzoni
Nic,
Yes... scrum boards with many sprints. Some concluded, others in progress and others that are about to start.
One issue we put in the first sprint and appears correct on the board, but the sprint has been completed but the issue does not. So we moved the issue to another sprint on the same board. However on the board it appears as being in the first sprint that has already been finalized
March 6, 2018
Once you've committed to dealing with an issue in a sprint (i.e. put it in a sprint, and started it), then the issue is part of that sprint.  If you don't complete it, and it goes into the next sprint or backlog, it still belonged to that sprint, even though you're going to put it into another sprint.  It will appear in the new sprint as well.
Fabio Manzoni
Thank you for your help Nic!
