Issues are not visible on Kanban/Scrum after converting from business to software project on prem
Alex Shirokko August 25, 2024 edited
We are in the process of migrating from the Jira data center to the cloud.
We have over 15 business projects on the prem and they all should be converted to software projects before migration, per Atlassian requirements. After project conversion, I created a Kanban board, checked all my permissions and... I do not see any issues neither on the board or in the backlog. I tried to create an issue in the converted project and still nothing is visible. Filters have been checked in case of some limitations.
If I go to the search or "issues" - I can see all issues and can work on them.
Further, I migrated this project to the cloud hoping to reconfigure it... but the same story - nothing is visible.
Can someone tell me what is the issue or possible cause?
Thank you in advance
Trudy Claspill
Hello @Alex Shirokko
What is the filter used by the kanban board?
Does the kanban board include a subquery to exclude issues that have a released Fix Version value?
Have all the issue Status values been mapped to columns for the kanban board?
Alex Shirokko August 26, 2024
Hi Trudy,
1. I checked the filter and it doesn't create any blockage
2. The Kanban board does not have any subquery. I even tried to create my own board.
3. Statuse values have been mapped automatically during migration.
I have no idea why I cannot see any issues.
Thank you anyway for finding time
Trudy Claspill
Can you share with use screen images of what you see for
  • the board
  • the filter
  • the status/column mapping
  • an example issue you would expect to see on the board?
Trudy... I have to visit a psychiatrist... I found the issue! It was as you said in the subquery of the original board. Thank you SO MUCH!
Trudy Claspill
I'm glad you found the cause.
If my answer helped you solve your issue, please consider clicking on the Accept Answer button to mark your Question as Solved.
