I recently migrated our projects from the server to the cloud. After the migration, I noticed that about 1/3 of the migrated projects have at least 2 issues missing in the Cloud version. I initially though this was done with permissions, but I am an Administrator for the project with the highest number of missing issues.
Also, is there a limitation on the Jira Cloud free plan migration compared to standard or premium. If yes, what is specifically restricted to the free version?
Hello @Gbadebo Ogunleye ,
It might be the case that issues has issue security to them may be for that reason you unable to see if not the case I would suggest you go to the Automation rule and in condition, find JQL and write query,
Project = XYZ so that it will show you the correct count.
Or you may reach out to Atlassian Support for help.
Mayur
Mayur,
If you can help on how to reach the support team, I will appreciate that. My inability to reach the support team led me here and I still do not have a solution.
This has been frustrating.
Regards.
Hi @Gbadebo Ogunleye ,
The best thing to do right now would be to review your migration plan and see if any of your migrated projects are less than 100% complete in their migration. It sounds like there were some problems with some of the issues being migrated. It happens - this is why testing is so incredibly important.
Have a look at the logs and see if there were any errors. I'd be happy to try to help further if you have more information.
Thanks for the response.
I have attached the screen shots from one of the migrations and as you can see, they were all migrated successfully at 100%, and the second screenshot shows no recorded error either.
The projects were migrated successfully and somehow I still have multiple issues missing across the board.
In that case, I have to agree with the assessment that this is likely due to issue-level security.
Can you see these issues in your server instance?
Rob,
Yes, I can see all the issues in the on premise version/server instance (that was how I was able to confirm that several issues are missing in the cloud). I am an administrator on both platforms and a project admin on one of the projects with missing issues.
Register now
