Issues table view
Jérôme Godbout
Is there a good way into JIRA to have a table view with customizable column for project issues? I really need to have some overview of some fields and I hate to have to open all issues individually. I need to sort quickly. I really feel the pain with JIRA GUI, it's inefficient to navigate and the there is so little information on each display. I just want a table view, come on that must be simple and obvious thing to do? no?
Something like the good Redmine:
Jérôme Godbout
Finally found it, the detail view by default is the list view with side panel of details and the "list view" is in fact the table/grid view.
When selecting that List View you are then able to have the column link where you can define which column you want. After that everything start to make sense.
So the List view is the table/grid view to sort and.
Nic Brough -Adaptavist-
October 3, 2018
Use the issue navigator.  Go to issues -> search and run a search (such as "project = x").  You can select what columns to display by default, and if you save the filter so you can run it again without having to build the query again, you can save the column layout with it.
Jérôme Godbout
This answer how to select which column, but not how to get the grid view. The problems was the details view doesn't have any column and this is the default view. List view is the grid table where you can have the column usage.
Unless I'm mistaken there is no way to have any column into the details view. The query was NOT the issue here.
