Dear Support-Team,
i´m checking out the new JIRA-Version 7.8.0 in our test-environment. I get the warning "database is using an unsupported collation" during the first startup.
I continue with the button "Ignore all warnings and continue. ...
If i will execute now an instance health check the result is that everyting is ok and the used collation seems to be "binary".
But if i execute the follow sql-statement against our test-database and against our productive oracle-database, i will get the result "GERMAN":
SELECT COALESCE(value, (SELECT value
FROM nls_database_parameters
WHERE parameter = 'NLS_SORT'))
FROM nls_session_parameters
So whats going on? i´m confused ... have we got a problem or not? Do we need to react and change something?
I´m looking forward for your reply.
Kind Regards
Hi there, Knut,
I can see you will run into problems as your Oracle database is 10g, and Jira 7.8 only supports 12c R1.
Once you upgrade Oracle, you can fix the collation issue here:
Let us know if you have any trouble!
Shannon
Hi Shannon,
we are using oracle 12.1.0.2 ... the shown database-type (10g) is not correct.
Knut
Knut,
Thank you for confirming that. Can you let me know if you were able to resolve the issue with the article I provided you?
Shannon
