Hi All, Hope you are doing well.
I am wondering if this would be possible at all.
Basically when my teams tickets are Moved from IN PROGRESS > CODE REVIEW I what to an alert to be sent out to the assignee that they need to log in time to the ticket.
Is this possible or if there is something similar I can trigger maybe send them an alert every 48 hours ?
(We agreed in our retro that we need some sort of alert as people forget to log time).
Hi @Raj Grewal ,
Based on my experience, you can find what you're trying to achieve using Notification Assistant for Jira Cloud.
Hope it helps.
Victor
Hi @Raj Grewal
Welcome to our Community.
Based on my experience, the best pratice may be to provide a workflow transition screen (with worklog entry) to let the developers log their time spent on those tickets.
Of course, you could choose to use jira automation to notifiy dev, but I don't suggest multiple times of notifications.
Hope it helps. Thanks,
YY哥, Cloze Tech
Thanks for the response is there a thread you can recommend about the automation side of things ?
I am unable to change the workflow at this current stage.
Hi @Raj Grewal
Please go to project setting. In the sidebar, there's automation for you to create the below rule:
Hope it helps you.
YY哥
Register now
