JIRA Agile 6.3 Worklog cache and Query result limit
Gregory Hicks
We just installed the Agile plug-in 6.3 and I am trying to understand the Caching and Query results limit. We have multiple projects using JIRA (close to 40 projects) and I have noticed after installing Agile the performance has slowed down a lot. I checked the Worklog Caching and it's at 24% and the default cache size is 20,000. Does this number need to be set so high? Also should I set a Query result limit for our projects and if so what would a exceptable number be?
I have been doing a lot of looking around and I don't see a whole lot of information on this so I wanted to reach out in hopes someone has found something and be helpful to others with the same questions.
Gregory Hicks
I am pretty sure everyone is using Rapid boards and Kaban.
Timothy
October 1, 2013
Quiestion. Are you using the classic board or rapid boards?
Help us plant more trees
