I'm stumped on why I'm unable to get the results list back from an API call.
Navigating to https://confluence.corp.com/rest/api/content?title=FOO%20BAR%20BAT I get:
{"results":[{"id":"1878008","type":"page","status":"current","title":"FOO BAR BAT","extensions":{"position":0},"_links":{"webui":"/display/MPSM/FOO+BAR+BAT","edit":"/pages/resumedraft.action?draftId=1878008&draftShareId=f22defd9-0e03-4932-a777-8af1350e9a75","tinyui":"/x/8ZwxCw","self":"https://confluenceent.cms.gov/rest/api/content/187800817"},"_expandable":{"container":"/rest/api/space/MPSM","metadata":"","operations":"","children":"/rest/api/content/1878008/child","restrictions":"/rest/api/content/1878008/restriction/byOperation","history":"/rest/api/content/1878008/history","ancestors":"","body":"","version":"","descendants":"/rest/api/content/1878008/descendant","space":"/rest/api/space/MPSM"}}],"start":0,"limit":25,"size":1,"_links":{"self":"https://confluence.corp.com/rest/api/content?title=FOO%20BAR%20BAT","base":"https://confluence.corp.com","context":""}}
When I enter the exact same web address into JIRA automation, I get back:
"results": [],
"start": 0,
"limit": 25,
"size": 0,
"_links": {
"self": "https://confluence.corp.com/rest/api/content?title=%22ESRD%20API%20Releases%22",
"base": "https://confluence.corp.com",
"context": ""
Here is a screenshot:
I get back a 200, so everything appears to be valid. I have checked that my account is good. I have made other API calls and they have worked. It is just simply this specific GET that's not returning any information. I have tried a number of options with the URL (space, expand, etc) just to see if I can get *something* back, but every time it's the empty JSON above.
Ultimately, my goal is just return "id" so I can use that as to reference a parent page for the creation of a new child age, but as you can see the results list is [] with no data so I'm completely stuck. I bet this is just something dumb but I've been stuck on this all day and I have a migraine. Any assistance would be appreciated.
EDIT 4/Mar/22
I suspect I might be losing my authorization (or something similar) because I get back the same empty string if I just send the call with no header. Oddly, I got this is work once this morning and then it stopped again. I suspect this might be something for my internal IT to resolve so I've opened a ticket with them.
I'm keeping this here and open so at the very least it can serve as a reference to others since I wasn't able to find anything on this specific problem via Google. I'll follow up as I get additional information and (hopefully) a resolution.
i have the same issue. Have you solved or found a solution please
if I put the url is working fine but when I put the smart value with {{createdpage.title}} I have no results.
I put the webrespuns in a comment , if a open the url the navigator show me the result correctly.
so I don’t’ understand what is wrong.
please help ^^
