JIRA Automation - Using .min and .max not returning results for lookupissues
Michelle S
I have a rule following these instructions, but {{lookupissues.<date>.min}} and {{lookupissues.<date>.max}} are both returning an empty value.  When I remove .min and .max, I get the 3 date values for the 3 children in the parent.
Is there currently an issue with .min and .max?
May 23, 2025
Hi @Michelle S
Just to confirm, are the fields you are using from advanced planning: Target Start and Target End?
If so, I believe those fields are text (and not date) values when accessed in an automation rule, and so the min / max functions will not work.  The fix is to convert them with the toDate function before the min / max functions:
{{lookupIssues.customfield_10022.toDate.min}}
and
{{lookupIssues.customfield_10023.toDate.max}}
Michelle S
Hi @Bill Sheboy  yes they are Target Start and End. And that fixed it. Thank you soooooooooooo much!!!!!!!
Like Bill Sheboy likes this
Michelle S
@Bill Sheboy While on the same topic, is there a way to find which parents have Target Start dates that start after child Target Start and parents with Target end dates that end before child Target End dates?  I'd like to run the JIRA automation to replace them only on affected ones but everywhere I look there isn't a jql that can do that
Michelle S
Actually, just found the answer I was looking for in a message you wrote here https://community.atlassian.com/forums/Jira-questions/how-to-set-list-of-values-to-smart-variable/qaq-p/2565674
but create a list from the branch to use in another branch...
May 23, 2025
Well done finding your own answer to that one!
Using rules is all about learning and experimentation :^)
May 23, 2025
Hi @Rohan
Please review the community guidelines for disclosing sources when posting bot / AI-generated content:
https://community.atlassian.com/forums/custom/page/page-id/rules-of-engagement
