JIRA Automation for creating issues in hierarchy
Naman Jain February 2, 2023
Hi Community,
We need to create automation in jira, while creating initiative issue type its child milestone and under milestone , feature issue type should be created automatically.
Create Issue - Initiative -> Milestone -> Feature
Thanks in Advance!
John Funk
February 3, 2023
HI Naman,
Have you created a rule yet? If so, can you share that?
Basically, you want to create a rule based on an Issue Created trigger. Then add a Condition to check if it is Issue Type of Initiative.
If so, then add an action for Create Issue. Fill in the information for the fields. Then add a Branch for Most recently created issue. Under the Branch add an action for Link Issues. Then choose the appropriate options that match the linkage you have in your Hierarchy.
