JIRA Automation microsoft teams Error communicating with the API 500
javier
January 14, 2022
I have a Jira automation rules in jira server. When an issue of a specific type is created I send a notification through a webhook to a microsoft teams channel. And with other rule I send a notification in case a field has some specific value to another different microsoft team channel.
Then thing is that sometimes all works fine but others I see the error in the rule register:
Send Microsoft Teams message
500
Any idea of what could be causing this sporadic issues or hot to solve or bypass this issue?
It is very importan that if something works works always and no notify in some cases and not in others.
Thanks a lot and best regards,
Erik Ekengren
Same issue here too. If anyone finds the cause of this error please post it here...
lemoi January 24, 2022
I have exactly the same issue, where you capable of identifying the root cause of the issue ?
moparsley April 15, 2022
Having the same issue.  Worked Tuesday 4/12122 and hasn't worked (i.e. get 500 error) since. Definitely sporadic.
moparsley August 1, 2022
Just a note that I'm no longer experiencing this issue (server edition)
SERVER
VERSION
8.20.1
