×I have an issue where I am trying to use the IMPORT CSV functionality against a JIRA project, to create issues and auto-populate their Original Estimate values. I have correctly followed the JJIRA formatting documentation here and here is a breakdown of my issue using screenshots:
My global work hours per day are 8hrs. As an example, I tested in this CSV import, where the original estimate value = 9000 seconds, yet after it imports it shows 2h against the Original Estimate field in the issue, instead of 2h 30m. In the same import file it successfully imports 18000 seconds as 5h.
Can anyone help advise why JIRA is incorrectly importing the original estimate data?
Mark
UPDATE: There is a known bug confiremd by Atlassian Support, which you can view here: https://jira.atlassian.com/browse/JRACLOUD-81938?focusedId=3687955&page=com.atlassian.jira.plugin.system.issuetabpanels:comment-tabpanel#comment-3687955 Pleaes UPVOTE the bug issue so we get this prioritised their side to be fixed!
Cheers
Mark
Hi @Mark Hawkins ,
We did big CSV import last quarter when migrating from another tool to Jira. We did experience some issues when 'translating' logged work values due to Tempo Timesheets app.
Basically, the underlying issue was with the global unit for time tracking settings, which was set to 'Days' instead of (default) 'Hours'.
Anyway, by the looks of it and as we're talking about estimates, this doesn't seem to be the case.
If you would check what value is actually stored for each item displaying incorrect Original estimate (e.g. https://<sitename>.atlassian.net/rest/api/latest/issue/BJIT-82), can you check which value is stated there? (try searching term 'timeoriginalestimate')
To return to our initial issue, we had to debug this together with Atlassian Support and Tempo support team in order to find a resolution. So, it might be the best bet to try contacting them to see if they can see what's going on in the backend. 👀
Tobi
Hi @Tomislav Tobijas - thanks for the advice, and we also use Tempo Timesheets. But I don't think the issue resides there, and at least I can't find a setting youb refer to - see here:
1. Tempo Logging Time Settings: https://gyazo.com/fe98d377f98ea076a6665d589fc0d200
2. Tempo Story Points Settings (which we don't actually use, as we estimate in hrs & minutes): https://gyazo.com/e9ed528cddda40280021c2a265b7d5a2
I actually wasn't aware about the api JSON result you showed me now - thanks. But I can see there that it is importing as 7200 seconds instead of the 9000seconds in my import file - see here: https://gyazo.com/4f16d09b304f1c85f1a6ab769377b949
And the ones I expect there to be minutes, are importing as ZERO - see here: https://gyazo.com/31c119bcb69abd4d8ffffa1a4714f004
If you have any ideas please do share, otherwise I will also contact Atlassian support.
@Mark Hawkins yeah, this seems like some kind of importer issue. I haven't stumbled (or at least I don't remember) having these completely different values before and after import.
Would definitelly recommend reaching out to Support directly, and if you find a resolution, it would be really helpful if you could share it here 🙏
@Tomislav Tobijas I chatted to Atlassian Support and they advised their a known bug since like 2018, and you can see my comment against the bug here, and the linked screenshot of my entire conversation with Atlassian Support about their bug and their proposed workaround: https://jira.atlassian.com/browse/JRACLOUD-81938?focusedId=3687955&page=com.atlassian.jira.plugin.system.issuetabpanels:comment-tabpanel#comment-3687955
Can you UPVOTE the bug issue so we get this prioritised their side to be fixed?
Cheers
Mark
@Mark Hawkins wow 😮 Never knew this is a thing... Everything in the background is stored in seconds and yet it kinda depends on the default unit set within the global settings.
Well, at least there's a workaround people can use, although it's not that pretty :/
In any case, thanks for sharing! I've voted for this and will keep an eye on developments. 👀
first off, I would definitely reach out to Atlassian Support. I don't see a reason why this wouldn't work natively.
Alternatively, if you're looking for an immediate solution, you may want to have a look at the app that my team and I are working on: JXL for Jira.
JXL is a full-fledged spreadsheet/table view for your work items (issues) that allows viewing, inline-editing, sorting, and filtering by all your work item fields, much like you’d do in e.g. Excel, Google Sheets, Smartsheet, or Airtable. It also comes with a long list of advanced features, including support for inline bulk editing via copy/paste. This works within JXL, but also across JXL and pretty much any other app, including e.g. Excel or Google Sheets.
This is how it looks in action:
JXL generally accepts any value as it would be entered directly in Jira. So if there's a way for you to easily get the data into this shape, this could be a quick and easy workaround.
I should also add that JXL can do much more than the above: From support for configurable work item hierarchies, to work item grouping by any issue field(s), sum-ups, or conditional formatting.
Best,
Hannes
