JIRA Capabilities
jalaj gupta June 2, 2023
We are evaluating JIRA Project Management for a client purpose (whether it can generate portfolio level reports, track resources, timelines and budget etc.)
Key requirements are -
  • Creating baseline project plan (once committed, this should not be allowed to change)
  • Generating alerts if any dates change from baseline plan (maintain versions of baselines)
  • Tracking timelines at portfolio level
  • Allocate resources and create a resource utilization view across the portfolio
  • Allocate budget and maintain planned v/s actual numbers (both need to be inputted manually for now)
Looking for some help if this can be done in JIRA?
Mark Segall
Hi @jalaj gupta and welcome to the community!
Short answer is that yes.  This can be done in Jira, but there's a bit of initial configuration overhead to get there...
    • You can create custom fields like Baseline Start/Baseline End.  As far as not being able to change, you could make use of a transition screen on a workflow and make that transition conditional so that only x individuals have ability to transition the screen.  Then leave the field on the issue VIEW screen, but remove from Create/Edit screens.
    • You would track actuals using fields like Target Start/End which comes with Advanced Roadmaps.  Then leverage automation to trigger when the Baseline Start/End are set to automatically set the Target Start/End.  You could then use another automation rule to alert if someone changes the Target Start/End.
    • Advanced Roadmaps (Jira Cloud Premium feature) can cover this.
    • If your intent is to track individuals, you're out of luck natively and would need to look for a marketplace app.  Jira is designed for Agile which is all about teams.  You can use different Advanced Roadmap views to group by objective/project or group by team.
    • If you're cool with managing manually, you could simply create custom fields for tracking planned v actual.  Anything more dynamic would require a 3rd party app and/or integration with your ERP
Note - If you're dealing with a sizable team working at scale, you could also explore Jira Align.  However, BIG CAVEAT is that it is pricy and designed for teams that have reached a level of agile at scale maturity and truly understands their objectives/OKRs.  Costs can start at $200-400k/year and ramp up quickly, but it does offer more features.
Nic Brough -Adaptavist-
June 2, 2023
Yes, Jira can do all of that, apart from the budgeting (it's not intended to be a financial tracking system, just an issue tracker).  You can add apps to it that enable financial features, or automate your own if you want.
