I have a problem with JIRA automation.
I need to add user automatically in to Multiuser custom field (přihlížející) everytime issue is created but do not overwrite users who were already selected in Create issue. Simply add the user to the existing users in that field.
I have easy rule in Jira Automation.
When issue is created -> edit issue -> set up custom field (přihlížející) to Martin Soukop.
I checked the internet for advise but didnt find anything that work :/
For example this is exactly what I need but that script didnt work for me when I edit it for my custom field... - https://community.atlassian.com/t5/Jira-Software-questions/JIRA-Automation-Add-Current-User-to-Custom-Field/qaq-p/1478453
Hello @Martin Vašíček
The documentation provides an example of using advanced editing with JSON to add another user to a multiple user picker field without overwriting the values that are already there.
If the instructions are unclear or do not appear to work correctly in your rule, you will need to provide us with screen images that show your complete rule, the details of each step, and the output that is written in the rule execution Audit Log when the rule is run.
Help us plant more trees
