JIRA Cloud ScriptRunner - Modifying Issue - UI is not updating
Pavel Antonenko November 4, 2016
I implemented script which auto-assign task for some user by executing script by ScriptRunner for Cloud.
The problem is as script modify user by async calling REST api it's done after UI shows issue, so in UI user is not updating. After resfresh off page everything is OK.
Any suggestions for workaround? I tried to sleep post-function for some time, but unsuccessfully.
Thanks in advance for any help! Scripting JIRA is cool, luckily we can do it in Cloud also now smile
4 votes
Jon Mort _Adaptavist_
November 4, 2016
Hi Pavel,
All add-on interaction with JIRA in the cloud is async so often the page is loaded before updates can be applied. It is a fundamental limitation with the Connect framework on which cloud add-ons are built. We do try to give an indication that the issue has been updated with a message, and when Atlassian support it we will add a button to refresh the issue on that message.
Sleeping in a post function will have no effect because JIRA does not wait for post functions to complete.
Regards, Jon
Robert Massaioli _Atlassian_
November 4, 2016
Dave Meyer
November 4, 2016
@Jon Mort (Adaptavist)'s overview of the problem is exactly correct. We expect to make improvements to the view issue page over the next year to address this problem. Please refer to ACJIRA-1098 for now.
Pavel Antonenko November 7, 2016
@Robert Massaioli @Dave Meyer @Jon Mort (Adaptavist)
Guys, thanks for answers!
I have seen some dialogs, for other plugins for updating visible tickets. Like
At least such dialog will help. Why Scriptrunner  doesn't show it?
Pavel
November 7, 2016
Hi Pavel,
I think that is ScriptRunner functionality. There are timing issues with it however so sometimes the script executes quickly and the change is not detected quickly enough. It really is a workaround until Atlassian address ACJIRA-1098.
Jon
