Hey there,
I am updating the all of my API endpoints to v3 and noticed something that was not expected when creating a comment. In the documentation the the add Comment endpoint the different for both API versions:
V2
body
string
The comment.
V3
body
anything
The comment.
When I assign the body field as a string using the V2 API it works all good. When I assignee the body field as a string in V3 I get the following error:
{"errorMessages":[],"errors":{"comment":"Comment body is not valid!"}}
Has something changed that the API document is not outlining?
Cheers, Phil
This problem was solved? I´m in the same situation right now.
Yes having same problem, found the docs here for v3:
https://developer.atlassian.com/cloud/jira/platform/rest/v3/#api-rest-api-3-issue-issueIdOrKey-comment-post
Also seems like the JSON payload returned for get issue has changed in V3. The description field is nested without other fields:
V2
"description": "example bug report",
V3
"description": { "type": "doc", "version": 1, "content": [ { "type": "paragraph", "content": [ { "type": "text", "text": "example bug report" } ] } ] },
Is there any reference to these changes?
Thank you. This solved my problem.
