I was wondering how I would export a single project. I have read about using the "Backup System"; however, I don't want to backup the whole system to get at one project.
https://answers.atlassian.com/questions/24187
Does anyone know of a tool or a method to just get at a single project? I am wanting to back it up in its current state then have the ability to restore it back to that state at a later time if needed.
Nope - there are a couple of add-ons in the marketplace that sort of do it partially, but they're not available for Cloud.
Hello @Jeremiah Landi @Nic Brough -Adaptavist-,
I am also getting the same issue. I can export a single issue but not the whole project. So, how can I export a whole project to local as XML file?
Same answer as above.
