×See the attached Screenshot.
That `div` is hidden but laying on top of User Stories in Active Sprints. These can't get clicked. Tasks can't get dragged and so on. It's blocking all mouse events obviously.
image2016-3-10 10:0:2.png
I don't really have a question. That's a bug and I don't know where else to report it.
That's very strange as other people aren't getting the problem.
But, whatever the cause, it definitely needs to be raised with Atlassian directly - as it is a Cloud installation and it's getting in your way, it should go to Cloud support over at https://support.atlassian.com
I would not raise it as a bug yet, as bugs go through triage and confirmation processes, whereas this might be settings or something Cloud is doing, and a support request will be looked at more quickly. If it is a bug, Support will then raise it as such.
from a frontend developers perspective: a hidden div is on top of others and is blocking mouse events. That's a bug.
I reported it on support.atlassian.com.
FYI: All users on our instance got that problem.
It's not a bug when it's something in the config or settings, or something outside the code.
You can't say that it's a bug until you know what the cause is. As other people using the same software are NOT getting it, there's a good chance that it is NOT in the code and hence it's NOT a bug. But we don't know that. Yet.
I looked into the code. And I doubt that there is a setting that says "show invisible feedback popup"
I'm sure there is a setting or something to turn that feedback popup off. Then it's gone and everything is good. But that doesn't make it not a bug when it's turned on. This can't be the expected behaviour in any configuration or setting. Even if it's a bug just for our specific config - it's still a bug.
I'm sorry, but you're wrong. We do not know that it is a bug. It's certainly something going wrong, but you do not know the cause. So you can't be sure it's a bug. I know this is a semantic point, but I believe in clarity and accuracy being useful things. You can't prove that it's a bug yet, so you can't state that it is.
yeah it is a semantic issue .
Configs and Settings change expected behaviour. Wrong and unexpected behaviour is a bug in my book. Doesn't matter though.
Let's agree to disagree. Thank you for taking the time and checking the issue out.
