=JIRA() Function failing to load data, stuck in 'error: Loading Data' state
Liam Blake March 2, 2022 edited
Hi All,
I have a table to organise my work here and the =JIRA function has stopped pulling in data for this sheet. Its the only sheet I have where this error has occurred. It stays in the loading state and won't pull data. I have enabled Jira Cloud for Sheets for this sheet and iterative calculations are on.
This is mystifying and really frustrating! I need this plugin working! Any help appreciated!
Liam Blake March 6, 2022
The same thing is STILL happening. Urgently need a fix for this. Atlassian support - where are you?
Natalie Simons March 6, 2022
Just checked my sheet and can confirm it's the same issue AGAIN. I thought these outages were supposed to be "few and far between" ?
Vojtěch Matějovský
March 3, 2022
The same issue yesterday. Today morning it was working, but after refresh, the error appears again :-/
Mustafa Slatewalla March 3, 2022
I am also stuck up. an extensive user of Jira cloud.. but things are messed up. need help
Natalie Simons March 3, 2022
Confirming that my team is having the same issue!
We only started using this add-on this week. Is it usually this unreliable?
If so, we'll need to look into a different solution I guess
Normally it isnt so bad.. a couple of time outs are there for sure, but by and large pretty reliable.
I must say that yesterday the other Jira Pulls through the JQL Function were intact, but pulls through Jira() function were a problem.
looks resolved for now, but would be good for #AtlassianSupport to comment on what happened.
Florian DUCLOY
March 4, 2022 edited
it was ok yesterday but same problem today "Error loading data"
(I've also tried to disconnect and revoke authorization)
Mustafa Slatewalla March 4, 2022
I tried all options and then just gave it up.
had raised the below issue, but closed it, since it started working
JST-739062 - Jira() function in Google cloud Integration has stopped working.
Florian DUCLOY
March 4, 2022
Note that in a new Spredsheet, the same Jira function works well.
But impossible to copy without lost all data ref in charts
Natalie Simons March 4, 2022
If I remake the spreadsheet, it works
But I can't for the life of me get it to work in the original spreadsheet. Any tips?
Update: original sheet is back online. 🥴
Thanks for the updates all.
Liam Blake March 7, 2022
Anyone know how to get the attention of atlassian support here? this is beginning to become really seriously problematic...
