JIRA Gets Locked after succesfull DB Precheck
Nitram
April 28, 2016
Recently I recreated the Test Db from the Live Dump, Later I Started JIRA, I got a message saying Precheck of DB Successful and it started to hang, when I checked the JIRA home Directory, I found the JIRA lock File, Could you please assist me in solving this issue.Thanks!
Nic Brough -Adaptavist-
April 28, 2016
There will be an error telling you why it has locked it in the log, if not on screen.
Nitram
April 28, 2016
Which log would you prefer to check cause last time, when I checked I didn't find anything, I don't know whether I am checking in the right place.
Nitram
April 28, 2016
I checked under atlassian-jira.log, but there is no issue
April 28, 2016
The application log always contains a reason for locking an instance.  atlassian-jira.log in <JIRA home>/log
Nitram
April 28, 2016
2016-04-28 08:14:43,737 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
JIRA 6.4.11 build: 64026 started. You can now access JIRA through your web browser.
2016-04-28 08:14:43,800 localhost-startStop-1 INFO [jira.upgrade.util.BuildNumberDao] Setting current version to 6.4.11
2016-04-28 08:14:43,815 localhost-startStop-1 INFO [jira.upgrade.util.BuildNumberDao] Setting downgrade version to 6.3.12
2016-04-28 08:14:45,315 localhost-startStop-1 INFO [plugins.hipchat.service.HipChatPluginLauncher] HipChat Plugin launched successfully
2016-04-28 08:14:45,628 localhost-startStop-1 INFO [plugins.dvcs.scheduler.DvcsScheduler] DvcsScheduler job handler registered
2016-04-28 08:14:45,706 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Returned module for key 'com.pyxis.greenhopper.jira:greenhopper-agile-shortcut' was null. Not enabling.
2016-04-28 08:14:45,706 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Returned module for key 'com.pyxis.greenhopper.jira:greenhopper-taskboard-shortcut' was null. Not enabling.
2016-04-28 08:14:45,706 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Returned module for key 'com.pyxis.greenhopper.jira:greenhopper-chartboard-shortcut' was null. Not enabling.
2016-04-28 08:14:45,706 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Returned module for key 'com.pyxis.greenhopper.jira:greenhopper-releasedboard-shortcut' was null. Not enabling.
2016-04-28 08:14:45,706 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Returned module for key 'com.pyxis.greenhopper.jira:greenhopper-boardsearch-shortcut' was null. Not enabling.
2016-04-28 08:14:45,721 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Returned module for key 'com.pyxis.greenhopper.jira:greenhopper-nextcolumn-shortcut' was null. Not enabling.
2016-04-28 08:14:45,721 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Returned module for key 'com.pyxis.greenhopper.jira:greenhopper-prevcolumn-shortcut' was null. Not enabling.
2016-04-28 08:14:45,721 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Returned module for key 'com.pyxis.greenhopper.jira:greenhopper-toggledetailview-shortcut' was null. Not enabling.
2016-04-28 08:14:45,721 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Returned module for key 'com.pyxis.greenhopper.jira:greenhopper-priority-shortcut' was null. Not enabling.
2016-04-28 08:14:45,721 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Returned module for key 'com.pyxis.greenhopper.jira:greenhopper-delete-shortcut' was null. Not enabling.
2016-04-28 08:14:45,721 localhost-startStop-1 INFO [greenhopper.plugin.sampledata.JiraImportersPluginInstallerImpl] Checking if jira-importers-plugin is present and at version 4.4 or higher
2016-04-28 08:14:45,721 localhost-startStop-1 INFO [greenhopper.plugin.sampledata.JiraImportersPluginInstallerImpl] jira-importers-plugin already at 7.0.12.
2016-04-28 08:14:50,737 localhost-startStop-1 INFO [greenhopper.service.logging.LogSupport]
Managed Issue Types
Epic id=20 name=Epic
Story id=21 name=Story
Managed Custom Fields
Epic Colour id=customfield_11205 name=Epic Color type=com.pyxis.greenhopper.jira:gh-epic-color
Epic Link id=customfield_11201 name=Epic Link type=com.pyxis.greenhopper.jira:gh-epic-link
Epic Name id=customfield_11204 name=Epic Name type=com.pyxis.greenhopper.jira:gh-epic-label
Epic Status id=customfield_11203 name=Epic Status type=com.pyxis.greenhopper.jira:gh-epic-status
Default Global Rank id=customfield_11500 name=Rank type=com.pyxis.greenhopper.jira:gh-lexo-rank
Sprint id=customfield_11200 name=Sprint type=com.pyxis.greenhopper.jira:gh-sprint
Story Points id=customfield_11208 name=Story Points type=com.atlassian.jira.plugin.system.customfieldtypes:float
Managed Issue Link Types
Epic Link Issue Link Type id=10200 name=Epic-Story Link
2016-04-28 08:14:54,003 Modification Check:thread-1 INFO [atlassian.jira.startup.JiraStartupLogger]
___ Modifications ___________________________
Modified Files : jira-application.properties
Removed Files : None
2016-04-28 08:14:54,034 localhost-startStop-1 WARN [jirafisheyeplugin.domain.fisheye.FishEyeManagerImpl] Error retrieving repositories for 'https://fisheye.openlink.com:8443/'
java.io.IOException: Error in remote call to 'fisheye' (https://fisheye.openlink.com:8443) [AbstractRestCommand{path='api/rest/repositories', params={}, methodType=POST}] : javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at com.atlassian.jirafisheyeplugin.rest.FishEyeRestApiManagerImpl.callFisheye(FishEyeRestApiManagerImpl.java:197)
at com.atlassian.jirafisheyeplugin.rest.FishEyeRestApiManagerImpl.callFisheye(FishEyeRestApiManagerImpl.java:124)
at com.atlassian.jirafisheyeplugin.domain.fisheye.FishEyeManagerImpl.getRepositories(FishEyeManagerImpl.java:117)
at com.atlassian.jirafisheyeplugin.domain.fisheye.FishEyeManagerImpl.updateInstanceRepositories(FishEyeManagerImpl.java:248)
at com.atlassian.jirafisheyeplugin.domain.fisheye.FishEyeManagerImpl.refresh(FishEyeManagerImpl.java:268)
at com.atlassian.jirafisheyeplugin.config.RefreshManagerImpl.refreshRefreshables(RefreshManagerImpl.java:161)
at com.atlassian.jirafisheyeplugin.config.RefreshManagerImpl.refreshAll(RefreshManagerImpl.java:79)
at com.atlassian.jirafisheyeplugin.config.RefreshManagerImpl.onStart(RefreshManagerImpl.java:93) <+3> (NativeMethodAccessorImpl.java:57) (DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:606)
at com.atlassian.event.internal.SingleParameterMethodListenerInvoker.invoke(SingleParameterMethodListenerInvoker.java:36)
at com.atlassian.event.internal.AsynchronousAbleEventDispatcher$1$1.run(AsynchronousAbleEventDispatcher.java:48)
at com.google.common.util.concurrent.MoreExecutors$SameThreadExecutorService.execute(MoreExecutors.java:253)
at com.atlassian.event.internal.AsynchronousAbleEventDispatcher.dispatch(AsynchronousAbleEventDispatcher.java:107)
at com.atlassian.event.internal.EventPublisherImpl.invokeListeners(EventPublisherImpl.java:160)
at com.atlassian.event.internal.EventPublisherImpl.publish(EventPublisherImpl.java:79)
at com.atlassian.plugin.event.impl.DefaultPluginEventManager.broadcast(DefaultPluginEventManager.java:84)
at com.atlassian.jira.upgrade.PluginUpgradeLauncher.start(PluginUpgradeLauncher.java:35)
at com.atlassian.jira.startup.ActiveServicesLauncher.start(ActiveServicesLauncher.java:51)
at com.atlassian.jira.startup.DefaultJiraLauncher$3.run(DefaultJiraLauncher.java:140)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrEnqueue(DatabaseConfigurationManagerImpl.java:345)
at com.atlassian.jira.config.database.DatabaseConfigurationManagerImpl.doNowOrWhenDatabaseActivated(DatabaseConfigurationManagerImpl.java:215)
at com.atlassian.jira.startup.DefaultJiraLauncher.postDbLaunch(DefaultJiraLauncher.java:124)
at com.atlassian.jira.startup.DefaultJiraLauncher.access$100(DefaultJiraLauncher.java:33)
at com.atlassian.jira.startup.DefaultJiraLauncher$1.run(DefaultJiraLauncher.java:86)
at com.atlassian.jira.util.devspeed.JiraDevSpeedTimer.run(JiraDevSpeedTimer.java:34)
at com.atlassian.jira.startup.DefaultJiraLauncher.start(DefaultJiraLauncher.java:81)
at com.atlassian.jira.startup.LauncherContextListener.contextInitialized(LauncherContextListener.java:72) <+5> (StandardContext.java:4992) (StandardContext.java:5490) (LifecycleBase.java:150) (ContainerBase.java:1575) (ContainerBase.java:1565)
at java.util.concurrent.FutureTask.run(FutureTask.java:262)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:744)
Caused by: com.atlassian.sal.api.net.ResponseException: javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at com.atlassian.sal.core.net.HttpClientRequest.executeAndReturn(HttpClientRequest.java:376)
at com.atlassian.plugins.rest.module.jersey.JerseyRequest.executeAndReturn(JerseyRequest.java:161)
at com.atlassian.applinks.core.auth.ApplicationLinkRequestAdaptor.execute(ApplicationLinkRequestAdaptor.java:84)
at com.atlassian.jirafisheyeplugin.rest.FishEyeRestApiManagerImpl.callFisheye(FishEyeRestApiManagerImpl.java:175)
... 38 more
at sun.security.ssl.Alerts.getSSLException(Alerts.java:192)
at sun.security.ssl.SSLSocketImpl.fatal(SSLSocketImpl.java:1884)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:276)
at sun.security.ssl.Handshaker.fatalSE(Handshaker.java:270)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1341)
at sun.security.ssl.ClientHandshaker.processMessage(ClientHandshaker.java:153)
at sun.security.ssl.Handshaker.processLoop(Handshaker.java:868)
at sun.security.ssl.Handshaker.process_record(Handshaker.java:804)
at sun.security.ssl.SSLSocketImpl.readRecord(SSLSocketImpl.java:1016)
at sun.security.ssl.SSLSocketImpl.performInitialHandshake(SSLSocketImpl.java:1312)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1339)
at sun.security.ssl.SSLSocketImpl.startHandshake(SSLSocketImpl.java:1323)
at org.apache.commons.httpclient.protocol.SSLProtocolSocketFactory.createSocket(SSLProtocolSocketFactory.java:175)
at com.atlassian.sal.core.net.CustomSSLProtocolSocketFactory.createSocket(CustomSSLProtocolSocketFactory.java:101)
at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707)
at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387)
at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323)
at com.atlassian.sal.core.net.HttpClientRequest.executeMethod(HttpClientRequest.java:587)
at com.atlassian.sal.core.net.HttpClientRequest.executeMethod(HttpClientRequest.java:546)
at com.atlassian.sal.core.net.HttpClientRequest.executeAndReturn(HttpClientRequest.java:350)
... 41 more
Caused by: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:385)
at sun.security.validator.PKIXValidator.engineValidate(PKIXValidator.java:292)
at sun.security.validator.Validator.validate(Validator.java:260)
at sun.security.ssl.X509TrustManagerImpl.validate(X509TrustManagerImpl.java:326)
at sun.security.ssl.X509TrustManagerImpl.checkTrusted(X509TrustManagerImpl.java:231)
at sun.security.ssl.ClientHandshaker.serverCertificate(ClientHandshaker.java:1323)
... 58 more
Caused by: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
at sun.security.provider.certpath.SunCertPathBuilder.engineBuild(SunCertPathBuilder.java:196)
at java.security.cert.CertPathBuilder.build(CertPathBuilder.java:268)
at sun.security.validator.PKIXValidator.doBuild(PKIXValidator.java:380)
... 64 more
2016-04-28 08:14:54,034 localhost-startStop-1 INFO [jira.whatsnew.listeners.WhatsNewUpgradeFinishedListenerImpl] Enabling show-whats-new-flag for all users
2016-04-28 08:14:54,034 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Returned module for key 'com.atlassian.jira.welcome.jira-welcome-plugin:show-whats-new-flag' was null. Not enabling.
2016-04-28 08:14:54,034 localhost-startStop-1 INFO [atlassian.jira.scheduler.JiraSchedulerLauncher] Starting the JIRA Scheduler....
2016-04-28 08:14:54,081 localhost-startStop-1 INFO [atlassian.jira.scheduler.JiraSchedulerLauncher] JIRA Scheduler started.
2016-04-28 08:14:56,143 localhost-startStop-1 INFO [jira.index.ha.DefaultIndexRecoveryManager] Latest index date: {2016-04-27 07:07:35}, Latest DB date: {2016-04-27 07:07:35}
2016-04-28 08:14:57,253 localhost-startStop-1 INFO [atlassian.jira.startup.LauncherContextListener] Memory Usage:
Heap memory : Used: 619 MiB. Committed: 1304 MiB. Max: 1989 MiB
Non-heap memory : Used: 189 MiB. Committed: 190 MiB. Max: 560 MiB
TOTAL : Used: 808 MiB. Committed: 1493 MiB. Max: 2549 MiB
2016-04-28 08:14:57,503 localhost-startStop-1 INFO [atlassian.jira.startup.DefaultJiraLauncher] Stopping launchers
2016-04-28 08:14:57,581 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Preparing to shut down the plugin system
2016-04-28 08:14:57,596 localhost-startStop-1 INFO [atlassian.plugin.manager.DefaultPluginManager] Shutting down the plugin system
2016-04-28 08:14:57,925 Timer-2 INFO [plugin.automation.scheduler.SchedulerInitializer] Unable to schedule the automation truncate log job. Retry 0 of 5
com.atlassian.scheduler.SchedulerRuntimeException: Unable to create the Quartz job and trigger
at com.atlassian.sal.jira.scheduling.JiraPluginScheduler.scheduleJob(JiraPluginScheduler.java:67)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:307)
at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.doInvoke(ServiceInvoker.java:58)
at org.springframework.osgi.service.importer.support.internal.aop.ServiceInvoker.invoke(ServiceInvoker.java:62)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.doProceed(DelegatingIntroductionInterceptor.java:131)
at org.springframework.aop.support.DelegatingIntroductionInterceptor.invoke(DelegatingIntroductionInterceptor.java:119)
at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invokeUnprivileged(ServiceTCCLInterceptor.java:56)
at org.springframework.osgi.service.util.internal.aop.ServiceTCCLInterceptor.invoke(ServiceTCCLInterceptor.java:39)
at org.springframework.osgi.service.importer.support.LocalBundleContextAdvice.invoke(LocalBundleContextAdvice.java:59)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
at com.sun.proxy.$Proxy3320.scheduleJob(Unknown Source)
at com.atlassian.plugin.automation.scheduler.SchedulerInitializer$2.run(SchedulerInitializer.java:167)
at com.atlassian.plugin.automation.scheduler.SchedulerInitializer.callWithRetry(SchedulerInitializer.java:236)
at com.atlassian.plugin.automation.scheduler.SchedulerInitializer.start(SchedulerInitializer.java:162)
at com.atlassian.plugin.automation.scheduler.SchedulerInitializer$1.run(SchedulerInitializer.java:108)
at java.util.TimerThread.mainLoop(Timer.java:555)
at java.util.TimerThread.run(Timer.java:505)
Caused by: com.atlassian.scheduler.SchedulerServiceException: Unable to create the Quartz job and trigger
at com.atlassian.scheduler.quartz1.Quartz1SchedulerFacade.checked(Quartz1SchedulerFacade.java:389)
at com.atlassian.scheduler.quartz1.Quartz1SchedulerFacade.scheduleJob(Quartz1SchedulerFacade.java:301)
at com.atlassian.scheduler.quartz1.Quartz1SchedulerService.scheduleJob(Quartz1SchedulerService.java:104)
at com.atlassian.scheduler.core.DelegatingSchedulerService.scheduleJob(DelegatingSchedulerService.java:66)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) <+1> (DelegatingMethodAccessorImpl.java:43)
at com.atlassian.plugin.osgi.hostcomponents.impl.DefaultComponentRegistrar$ContextClassLoaderSettingInvocationHandler.invoke(DefaultComponentRegistrar.java:134)
at com.sun.proxy.$Proxy140.scheduleJob(Unknown Source) <+3> (NativeMethodAccessorImpl.java:57) (DelegatingMethodAccessorImpl.java:43)
at com.atlassian.plugin.osgi.bridge.external.HostComponentFactoryBean$DynamicServiceInvocationHandler.invoke(HostComponentFactoryBean.java:154)
at com.atlassian.sal.jira.scheduling.JiraPluginScheduler.scheduleJob(JiraPluginScheduler.java:63)
... 27 more
Caused by: org.quartz.SchedulerException: The Scheduler has been shutdown.
at org.quartz.core.QuartzScheduler.validateState(QuartzScheduler.java:727)
at org.quartz.core.QuartzScheduler.scheduleJob(QuartzScheduler.java:778)
at org.quartz.impl.StdScheduler.scheduleJob(StdScheduler.java:243)
at com.atlassian.scheduler.quartz1.Quartz1SchedulerFacade.scheduleJob(Quartz1SchedulerFacade.java:297)
... 42 more
2016-04-28 08:14:58,925 Timer-2 INFO [plugin.automation.scheduler.SchedulerInitializer] Unable to schedule the automation truncate log job. Retry 1 of 5
... 27 more
... 42 more
2016-04-28 08:15:00,925 Timer-2 INFO [plugin.automation.scheduler.SchedulerInitializer] Unable to schedule the automation truncate log job. Retry 2 of 5
at sun.reflect.GeneratedMethodAccessor235.invoke(Unknown Source)
at com.sun.proxy.$Proxy140.scheduleJob(Unknown Source) <+2> (DelegatingMethodAccessorImpl.java:43)
... 27 more
... 40 more
2016-04-28 08:15:02,550 Timer-1 INFO [greenhopper.service.logging.LogSupport]
Atlassian GreenHopper v6.7.11 #71a5197f0180dc1d built 2015-08-11T02:56:33.404-04:00 - plugin stopping...
2016-04-28 08:15:02,550 Timer-1 WARN [atlassian.greenhopper.service.BridgeServiceLocator] The GreenHopper BridgeServiceLocator has been unwired and is no longer usable
Atlassian GreenHopper v6.7.11 #71a5197f0180dc1d built 2015-08-11T02:56:33.404-04:00 - plugin stopped
2016-04-28 08:15:03,065 Timer-1 INFO [plugins.dvcs.scheduler.DvcsScheduler] DvcsScheduler job handler unregistered
2016-04-28 08:15:03,081 Timer-1 INFO [plugins.dvcs.listener.DvcsAddUserListener] Attempting to unregister listener ...
2016-04-28 08:15:03,081 Timer-1 INFO [plugins.dvcs.listener.DvcsAddUserListener] Listener unregistered ...
2016-04-28 08:15:03,925 Timer-2 INFO [plugin.automation.scheduler.SchedulerInitializer] Unable to schedule the automation truncate log job. Retry 3 of 5
org.springframework.osgi.service.importer.ServiceProxyDestroyedException: service proxy has been destroyed
at org.springframework.osgi.service.importer.support.internal.aop.ServiceDynamicInterceptor$ServiceLookUpCallback.doWithRetry(ServiceDynamicInterceptor.java:105)
at org.springframework.osgi.service.importer.support.internal.support.RetryTemplate.execute(RetryTemplate.java:83)
at org.springframework.osgi.service.importer.support.internal.aop.ServiceDynamicInterceptor.lookupService(ServiceDynamicInterceptor.java:430)
at org.springframework.osgi.service.importer.support.internal.aop.ServiceDynamicInterceptor.getTarget(ServiceDynamicInterceptor.java:415)
2016-04-28 08:15:05,596 Timer-1 INFO [jira.plugins.monitor.MonitoringScheduler] Unscheduling metrics collector...
2016-04-28 08:15:05,596 Timer-1 INFO [jira.plugins.monitor.MonitorLauncher] Stopped JIRA monitoring
2016-04-28 08:15:05,659 Timer-1 ERROR [atlassian.event.internal.AsynchronousAbleEventDispatcher] There was an exception thrown trying to dispatch event [com.atlassian.plugin.event.events.PluginModuleUnavailableEvent@481d327c] from the invoker [SingleParameterMethodListenerInvoker{method=public void com.atlassian.plugin.manager.DefaultPluginManager.onPluginModuleUnavailable(com.atlassian.plugin.event.events.PluginModuleUnavailableEvent), listener=com.atlassian.jira.plugin.JiraPluginManager@4ed6595d}]
java.lang.RuntimeException: service proxy has been destroyed
at com.atlassian.event.internal.SingleParameterMethodListenerInvoker.invoke(SingleParameterMethodListenerInvoker.java:54)
at com.atlassian.plugin.osgi.factory.UnrecognizedModuleDescriptorServiceTrackerCustomizer.removedService(UnrecognizedModuleDescriptorServiceTrackerCustomizer.java:141)
at org.osgi.util.tracker.ServiceTracker$Tracked.customizerRemoved(ServiceTracker.java:922)
at org.osgi.util.tracker.AbstractTracked.untrack(AbstractTracked.java:351)
at org.osgi.util.tracker.ServiceTracker$Tracked.serviceChanged(ServiceTracker.java:865)
at org.apache.felix.framework.util.EventDispatcher.invokeServiceListenerCallback(EventDispatcher.java:864)
at org.apache.felix.framework.util.EventDispatcher.fireEventImmediately(EventDispatcher.java:732)
at org.apache.felix.framework.util.EventDispatcher.fireServiceEvent(EventDispatcher.java:662)
at org.apache.felix.framework.Felix.fireServiceEvent(Felix.java:3726)
at org.apache.felix.framework.Felix.access$000(Felix.java:80)
at org.apache.felix.framework.Felix$2.serviceChanged(Felix.java:717)
at org.apache.felix.framework.ServiceRegistry.unregisterService(ServiceRegistry.java:135)
at org.apache.felix.framework.ServiceRegistrationImpl.unregister(ServiceRegistrationImpl.java:129)
at org.springframework.osgi.service.exporter.support.internal.support.ServiceRegistrationDecorator.unregister(ServiceRegistrationDecorator.java:65)
at org.springframework.osgi.util.OsgiServiceUtils.unregisterService(OsgiServiceUtils.java:41)
at org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean.unregisterService(OsgiServiceFactoryBean.java:372)
at org.springframework.osgi.service.exporter.support.OsgiServiceFactoryBean.unregisterService(OsgiServiceFactoryBean.java:362)
at org.springframework.osgi.service.exporter.support.AbstractOsgiServiceExporter.destroy(AbstractOsgiServiceExporter.java:84)
at org.springframework.beans.factory.support.DisposableBeanAdapter.destroy(DisposableBeanAdapter.java:151)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.destroyBean(DefaultSingletonBeanRegistry.java:487)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.destroySingleton(DefaultSingletonBeanRegistry.java:462)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.destroySingletons(DefaultSingletonBeanRegistry.java:430)
at org.springframework.context.support.AbstractApplicationContext.destroyBeans(AbstractApplicationContext.java:853)
at org.springframework.osgi.context.support.AbstractOsgiBundleApplicationContext.destroyBeans(AbstractOsgiBundleApplicationContext.java:204)
at org.springframework.context.support.AbstractApplicationContext.doClose(AbstractApplicationContext.java:831)
at org.springframework.osgi.context.support.AbstractOsgiBundleApplicationContext.doClose(AbstractOsgiBundleApplicationContext.java:197)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.access$501(AbstractDelegatedExecutionApplicationContext.java:69)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext$2.run(AbstractDelegatedExecutionApplicationContext.java:214)
at org.springframework.osgi.util.internal.PrivilegedUtils.executeWithCustomTCCL(PrivilegedUtils.java:85)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.normalClose(AbstractDelegatedExecutionApplicationContext.java:210)
at org.springframework.osgi.extender.internal.dependencies.startup.DependencyWaiterApplicationContextExecutor.close(DependencyWaiterApplicationContextExecutor.java:374)
at org.springframework.osgi.context.support.AbstractDelegatedExecutionApplicationContext.doClose(AbstractDelegatedExecutionApplicationContext.java:236)
at org.springframework.context.support.AbstractApplicationContext.close(AbstractApplicationContext.java:794)
at org.springframework.osgi.extender.internal.activator.ContextLoaderListener$1.run(ContextLoaderListener.java:522)
at org.springframework.osgi.extender.internal.util.concurrent.RunnableTimedExecution$MonitoredRunnable.run(RunnableTimedExecution.java:60)
at org.springframework.scheduling.timer.DelegatingTimerTask.run(DelegatingTimerTask.java:66)
Caused by: org.springframework.osgi.service.importer.ServiceProxyDestroyedException: service proxy has been destroyed
at com.sun.proxy.$Proxy622.unregister(Unknown Source)
at com.atlassian.jira.less.impl.DynamicLookAndFeelUriResolver.disabled(DynamicLookAndFeelUriResolver.java:49)
at com.atlassian.plugins.less.UriResolverModuleDescriptor.disabled(UriResolverModuleDescriptor.java:29)
at com.atlassian.plugin.manager.DefaultPluginManager.publishModuleDisabledEvents(DefaultPluginManager.java:2067)
at com.atlassian.plugin.manager.DefaultPluginManager.notifyModuleDisabled(DefaultPluginManager.java:2054)
at com.atlassian.plugin.manager.DefaultPluginManager.onPluginModuleUnavailable(DefaultPluginManager.java:719) <+2> (DelegatingMethodAccessorImpl.java:43)
... 43 more
2016-04-28 08:15:07,925 Timer-2 INFO [plugin.automation.scheduler.SchedulerInitializer] Unable to schedule the automation truncate log job. Retry 4 of 5
2016-04-28 08:27:31,992 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
JIRA starting...
2016-04-28 08:27:32,242 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger]
___ Environment _____________________________
JIRA Build : 6.4.11#64026-sha1:78f6ec473a3f058bd5d6c30e9319c7ab376bdb9c
Build Date : Tue Aug 25 00:00:00 EDT 2015
JIRA Installation Type : Standalone
Application Server : Apache Tomcat/7.0.55 - Servlet API 3.0
Java Version : 1.7.0_45 - Oracle Corporation
Current Working Directory : C:\Program Files (x86)\Atlassian\JIRA\bin
Maximum Allowable Memory : 683MB
Total Memory : 357MB
Free Memory : 140MB
Used Memory : 217MB
Memory Pool: Code Cache : Code Cache: init = 2555904(2496K) used = 2721472(2657K) committed = 2818048(2752K) max = 50331648(49152K)
Memory Pool: PS Eden Space : PS Eden Space: init = 67633152(66048K) used = 112032752(109406K) committed = 131596288(128512K) max = 142606336(139264K)
Memory Pool: PS Survivor Space : PS Survivor Space: init = 11010048(10752K) used = 22916040(22378K) committed = 63963136(62464K) max = 63963136(62464K)
Memory Pool: PS Old Gen : PS Old Gen: init = 179306496(175104K) used = 92872912(90696K) committed = 179306496(175104K) max = 536870912(524288K)
Memory Pool: PS Perm Gen : PS Perm Gen: init = 22020096(21504K) used = 19702840(19241K) committed = 28835840(28160K) max = 268435456(262144K)
JVM Input Arguments : -XX:MaxPermSize=256m -Xms256m -Xmx768m -Djava.awt.headless=true -Datlassian.standalone=JIRA -Dorg.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER=true -Dmail.mime.decodeparameters=true -Dorg.dom4j.factory=com.atlassian.core.xml.InterningDocumentFactory -XX:+PrintGCDateStamps -XX:-OmitStackTraceInFastThrow -Djava.util.logging.config.file=C:\Program Files (x86)\Atlassian\JIRA\conf\logging.properties -Djava.util.logging.manager=org.apache.juli.ClassLoaderLogManager -Djava.endorsed.dirs=C:\Program Files (x86)\Atlassian\JIRA\endorsed -Dcatalina.base=C:\Program Files (x86)\Atlassian\JIRA -Dcatalina.home=C:\Program Files (x86)\Atlassian\JIRA -Djava.io.tmpdir=C:\Program Files (x86)\Atlassian\JIRA\temp
Java Compatibility Information : JIRA version = 6.4.11, Java Version = 1.7.0_45
___ Java System Properties ________________
atlassian.standalone : JIRA
awt.toolkit : sun.awt.windows.WToolkit
catalina.base : C:\Program Files (x86)\Atlassian\JIRA
catalina.home : C:\Program Files (x86)\Atlassian\JIRA
catalina.useNaming : true
common.loader : ${catalina.base}/lib,
${catalina.base}/lib/*.jar,
${catalina.home}/lib,
${catalina.home}/lib/*.jar
file.encoding : Cp1252
file.encoding.pkg : sun.io
java.awt.graphicsenv : sun.awt.Win32GraphicsEnvironment
java.awt.headless : true
java.awt.printerjob : sun.awt.windows.WPrinterJob
java.class.version : 51.0
java.home : c:\dev_stuff\java\jdk1.7.0_45_x64\jre
java.io.tmpdir : C:\Program Files (x86)\Atlassian\JIRA\temp
java.naming.factory.initial : org.apache.naming.java.javaURLContextFactory
java.naming.factory.url.pkgs : org.apache.naming
java.runtime.name : Java(TM) SE Runtime Environment
java.runtime.version : 1.7.0_45-b18
java.specification.name : Java Platform API Specification
java.specification.vendor : Oracle Corporation
java.specification.version : 1.7
java.util.logging.config.file : C:\Program Files (x86)\Atlassian\JIRA\conf\logging.properties
java.util.logging.manager : org.apache.juli.ClassLoaderLogManager
java.vendor : Oracle Corporation
java.vendor.url : http://java.oracle.com/
java.vendor.url.bug : http://bugreport.sun.com/bugreport/
java.version : 1.7.0_45
java.vm.info : mixed mode
java.vm.name : Java HotSpot(TM) 64-Bit Server VM
java.vm.specification.name : Java Virtual Machine Specification
java.vm.specification.vendor : Oracle Corporation
java.vm.specification.version : 1.7
java.vm.vendor : Oracle Corporation
java.vm.version : 24.45-b08
mail.mime.decodeparameters : true
org.apache.catalina.startup.ContextConfig.jarsToSkip :
org.apache.catalina.startup.TldConfig.jarsToSkip : tomcat7-websocket.jar
org.apache.jasper.runtime.BodyContentImpl.LIMIT_BUFFER : true
org.dom4j.factory : com.atlassian.core.xml.InterningDocumentFactory
os.arch : amd64
os.name : Windows Server 2008 R2
os.version : 6.1
package.access : sun.,
org.apache.catalina.,
org.apache.coyote.,
org.apache.jasper.,
org.apache.naming.resources.,
org.apache.tomcat.
package.definition : sun.,
java.,
org.apache.coyote.,
org.apache.jasper.,
org.apache.naming.,
org.apache.tomcat.
server.loader :
shared.loader :
sun.arch.data.model : 64
sun.boot.library.path : c:\dev_stuff\java\jdk1.7.0_45_x64\jre\bin
sun.cpu.endian : little
sun.cpu.isalist : amd64
sun.desktop : windows
sun.io.unicode.encoding : UnicodeLittle
sun.java.command : org.apache.catalina.startup.Bootstrap start
sun.java.launcher : SUN_STANDARD
sun.jnu.encoding : Cp1252
sun.management.compiler : HotSpot 64-Bit Tiered Compilers
sun.os.patch.level : Service Pack 1
tomcat.util.buf.StringCache.byte.enabled : true
tomcat.util.scan.DefaultJarScanner.jarsToSkip : bootstrap.jar,
commons-daemon.jar,
tomcat-juli.jar,
annotations-api.jar,
el-api.jar,
jsp-api.jar,
servlet-api.jar,
websocket-api.jar,
catalina.jar,
catalina-ant.jar,
catalina-ha.jar,
catalina-tribes.jar,
jasper.jar,
jasper-el.jar,
ecj-*.jar,
tomcat-api.jar,
tomcat-util.jar,
tomcat-coyote.jar,
tomcat-dbcp.jar,
tomcat-jni.jar,
tomcat-spdy.jar,
tomcat-i18n-en.jar,
tomcat-i18n-es.jar,
tomcat-i18n-fr.jar,
tomcat-i18n-ja.jar,
tomcat-juli-adapters.jar,
catalina-jmx-remote.jar,
catalina-ws.jar,
tomcat-jdbc.jar,
tools.jar,
commons-beanutils*.jar,
commons-codec*.jar,
commons-collections*.jar,
commons-dbcp*.jar,
commons-digester*.jar,
commons-fileupload*.jar,
commons-httpclient*.jar,
commons-io*.jar,
commons-lang*.jar,
commons-logging*.jar,
commons-math*.jar,
commons-pool*.jar,
jstl.jar,
geronimo-spec-jaxrpc*.jar,
wsdl4j*.jar,
ant.jar,
ant-junit*.jar,
aspectj*.jar,
jmx.jar,
h2*.jar,
hibernate*.jar,
httpclient*.jar,
jmx-tools.jar,
jta*.jar,
log4j.jar,
log4j-1*.jar,
mail*.jar,
slf4j*.jar,
xercesImpl.jar,
xmlParserAPIs.jar,
xml-apis.jar,
junit.jar,
junit-*.jar,
hamcrest*.jar,
org.hamcrest*.jar,
ant-launcher.jar,
cobertura-*.jar,
asm-*.jar,
dom4j-*.jar,
icu4j-*.jar,
jaxen-*.jar,
jdom-*.jar,
jetty-*.jar,
oro-*.jar,
servlet-api-*.jar,
tagsoup-*.jar,
xmlParserAPIs-*.jar,
xom-*.jar
user.country : US
user.dir : C:\Program Files (x86)\Atlassian\JIRA\bin
user.home : C:\Users\mraj
user.language : en
user.name : mraj
user.script :
user.timezone : America/New_York
user.variant :
2016-04-28 08:27:32,586 localhost-startStop-1 INFO [atlassian.jira.startup.JiraHomeStartupCheck] The jira.home directory 'C:\Program Files (x86)\Atlassian\Application Data\JIRA' is validated and locked for exclusive use by this instance.
2016-04-28 08:27:32,601 localhost-startStop-1 INFO [jira.config.database.SystemDatabaseConfigurationLoader] Reading database configuration from C:\Program Files (x86)\Atlassian\Application Data\JIRA\dbconfig.xml
2016-04-28 08:27:32,773 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger] Running JIRA startup checks.
2016-04-28 08:27:32,773 localhost-startStop-1 INFO [atlassian.jira.startup.JiraStartupLogger] JIRA pre-database startup checks completed successfully.
April 28, 2016
There's a load more after "pre-database startup checks" before JIRA is started (or locked)
