I want to assign the issue to the reporter (default), unless the user wants to assign
it to a different user (assignee field is shown on workflow screen).
Any suggestions?
you can write a postfunction and assigne it to reporter if the assignee is empty
you can do this using script runner plugin also,
https://jamieechlin.atlassian.net/wiki/display/GRV/Script+Runner
You could add this into your field configuration. Add the reporter by default when create issue :
<script type="text/javascript"> jQuery(document).ready(function($) { JIRA.bind(JIRA.Events.NEW_CONTENT_ADDED, function (e, context) { setAssignee(); }); setAssignee(); function setAssignee(){ var setUser = AJS.$("#reporter-field").val(); alert (setUser); AJS.$("#assignee-field").val(setUser); } }); </script>
