we are planning to integrate Jira with Dell STAT migration tool and are looking for option to integrate with RESt API's.
Are there any add-on's to support this type of integration ?
Newer Stat releases (since 2017) have included a REST api which makes integrating with Jira and other tools much easier than the web services. Here is a link demonstrating how one might setup bi-directional integration with Stat and Jira:
https://www.quest.com/video/integrate-stat-and-jira-using-rest-api8143842/
hello,
part of STAT is based on PeopleSoft/PeopleTools, so why not using PeopleTools Integration Broker for that purpose ?
Stéphane.
There do not seem to be any Apps for this in the marketplace, so you will probably have to write your own integrations.
Start over at https://developer.atlassian.com/server/jira/platform/rest-apis/
Thanks Nic for the reply,
Do you recommend researching on Jira Webhooks ?
Register today
