We are using below tools:
Jira as Test managment tool
Zephyr Plug-in - for writing testcases in Jira
UFT - Automation Tool
So we have Automation testcases in Jira with zephyr plugin. I need to Integrate UFT with Jira to update Automation execution results. Anyone tried it and was it successful?
Can you suggest how this can be performed?
I have found a similar thread in the Zephyr community and, in there, they suggest this can be achieved by using ZAPI (Zephyr API) or the Zephyr for Jira Test Management Plugin for Jenkins or Bamboo (depending if you use Cloud or Server).
For more details please refer to the original thread on Zephyr community:
Another way to achieve the same results is to use the UFT for Bamboo plugin as mentioned in an old thread I have found in here:
However, being these 3rd party tools, I would advise to also get in touch with Zephyr support in order to get further help on this.
I hope this helps.
Dario
You are very welcome @Charanya Muthukaruppiah .
Please review the provided links and, if it helped, kindly accept my answer :)
Dario
UFT does not have any specific and official featured integration just like ALM but you can find integration solution :
https://q-automations.com/2020/04/03/uft-integration-with-xray-jira/
