JIRA Issue calendar not displaying issues
Liz June 4, 2018
Hey, I can get the Jira Issues Calendar to display issues. It stopped working after we updated some permissions, but as an administrator, I can't see what's changed that would stop this working.
The error message is:
The filter chosen for this issue calendar either does not exist or has not been shared with you.
Any ideas? :/
Yogesh Mude
June 4, 2018
Hi @Liz
As per the error message has been displayed please check if the issue matches with the Filter or not.
if yes, then check the Filter to which group/project/role has been shared and are you part of that group/project/role.
https://confluence.atlassian.com/adminjiracloud/managing-shared-filters-818578900.html
Liz June 4, 2018
Thanks for your quick response Yogesh.
Where do I view the filter for the Jira Issues Calendar?
Liz June 4, 2018
Sorry just found it.
Liz June 4, 2018
Sorted it. Thank you!
Yogesh Mude
June 4, 2018
Hey if you feel this answer could help you to solve your issue then please don't hesitate to accept this answer.
It will help other those who will face the same issue in future.
Like Gopinath Lingerker likes this
