JIRA JQL: How can I search for a select version and newer?
Jeremiah Landi
Right now I have the following query:
project = xxxx AND fixVersion in (3.4, 3.4.1, 3.4.2)
I want a way to find issues within the project greater than or equality to 3.4. Is this possible?
Also, is there a way to just say currentVersion () like you can with openSprints ()?
I found an Answer that was closed but involved doing a wild card search.
https://answers.atlassian.com/questions/30052/jql-wildcard-search-of-version-list-like-fixversion
Nic Brough -Adaptavist-
January 21, 2016
I suspect the best you can do is earliestUnreleasedVersion() and latestReleasedVersion() for finding the current one (you can have many versions so currentVersion would simply beg the question "which one"?).
And unreleasedVersions() and releasedVersions() can help you with the ranges as long as you're strict on releasing versions when you should.
