JIRA: Need count of stories under an epic
Jyotirmay December 13, 2018
We need to make a dashboard displaying below two values
Epic Name            No of stories created under Epic
Please help us to count the stories. We are not able to find any plugin so far so may be script needs to be written. Please help!
Raimundas Juska
December 13, 2018
You can also try this app - https://marketplace.atlassian.com/apps/1219429/status-progress-report-gadget-for-jira
You would need to enter JQL such as - "Epic Link" = "name of your epic" and type = story
Mayur Ingale May 6, 2019
Thanks, Raimundas... and appreciate your efforts on the creation of such a good plugin.
But 'Status & Progress Report Gadget for Jira' is only available for Cloud version not for Self-hosted server version.
Alexey Matveev
December 13, 2018
You would need an add-on for it.
You could also use the Power Custom Fields Premium add-on:
https://marketplace.atlassian.com/apps/1210749/power-custom-fields-premium?hosting=server&tab=overview
You could create a SIL custom field with a script like this:
return size(allLinkedIssues(key, "Epic-Story Link"));
Marc Minten (EVS)
December 13, 2018
If you have scriptrunner, just create a Scripted Field.
The script should look like
IssueLinkManager issueLinkManager = ComponentAccessor.getIssueLinkManager()
Integer stories = 0
issueLinkManager.getOutwardLinks(issue.getId()).each {epicLink ->
if (epicLink.getIssueLinkType().getName() == "Epic-Story Link") {
Issue epicLinkedIssue = epicLink.getDestinationObject()
String liIssueType = epicLinkedIssue.getIssueType().getName()
if (liIssueType == "Story") {
stories+=1
return stories.toDouble()
Mayur Ingale April 29, 2019
epicLinkedIssue is not acceptable in code by Script runner Script field?
Any suggestion?
Marc Minten (EVS)
May 6, 2019
What do you mean with "...is not acceptable..." ???
Like • Roger likes this
While creating a Script field using Scriptrunner... its giving red indicator.
Marc Minten (EVS)
May 6, 2019
Just add the line
at the beginning of your script ? (that's just very basic groovy knowledge …)
