JIRA: Possibility to restrict comments to certain users
Müller_ Julian June 21, 2018
I have a question and think that someone can help me ;-)
We are using JIRA Software and would like send passwords to costumers.
Is there a possibility (maybe with a plugin) to restrict comments to certain users f.e. the author of the task?
Or is there a simple plugin to send messages to the costumers? Something which is small and not to expansive.
I'm looking forward to your suggestions.
Julian
Moses Thomas
@Müller_ JulianSure, update the permission scheme in the  project setting so that users have no permissions  to  comment.
Best!
@Moses ThomasThanks a lot for your answer, but I think you did not understand me. My description was bad i think :( I don't want to restrict the possibility to comment, I want to restrict the visibility, so that only the author (or another person) can view the comment.
With this feature, I could give passwords to costumers.
Moses Thomas
Ok that could work ;-) thanks a lot.
Moses Thomas
@Müller_ JulianGreat please mark solution as accepted/vote, so  others could use :)
Best!.
Sravan Kumar July 12, 2018
Hello @Moses Thomas
I have a requirement which is similar to what you solved, Could you please help me with the same:  Is there a possibility to restrain some fields based on the Groups after the Ticket is created?
For example: I want everyone to be able to write "Summary field" but once the ticket gets created only the Project Admin should be able to edit the "Summary field" thereafter.
Thank You
Read the story
