JIRA Project Permissions - Restricting Access
Gregg.Roseker@amido.com August 2, 2018
Is it possible to restrict access to a JIRA project for a group of users, so they are able to Read anything but the only Edit or Write access they have is to create or amend Comments on an issue?
I ask this question because I share access to a JIRA project with my client and they keep altering the description field (which contains acceptance criteria) after issues have been committed to a sprint. I don't want to restrict their access to Read Only for the entire project. I just want to stop them from amending the description field.
Gregg
Tansu Akdeniz
Hi Gregg.Roseker@amido.com,
Yes, you can.
  • Go to the Project Settings -> Permissions
  • You need to remove EDIT ISSUES permission from the customer.
  • If you only want them create issue and comment, add CREATE ISSUE, BROWSE PROJECT, ADD COMMENT permissions, remove all others.
Here the related KB that may help you:
https://confluence.atlassian.com/adminjiraserver073/managing-project-permissions-861253293.html
Thanks, Tansu. I will give it a try!
Moses Thomas
Gregg.Roseker@amido.comAs Jira admin,  you  can  set it in  the permission  scheme in the  Project  under  project  setting.
Best!
Thanks, Moses.
