JIRA REST API - 401 Unauthorised - for administrator level user
OharaSi March 5, 2013
I've been trying for days to use the REST api via basic http auth using curl (this is just the first step toward using the api in an app!) but keep getting a 401 response. I've looked everywhere throughout the configuration settings, user preferences etc and can find anything else to change. What am I doing wrong?
Mode: Private
Accept remote API calls: ON
example curl:
$ curl -D- -u uname:pword -X GET -H "Content-Type: application/json" https://myjira.atlassian.net/jira/rest/api/2/project
From the documentation I can find this is all I should need and should be providing me with JSON data but I get 401. Is there a setting somewhere (undocumented) that will allow my user account to access the data from this on-demand instance?
OharaSi October 23, 2013
I found that (after a lot of research and frustration with the documentation) the issue was I was trying to interface with the JIRA restful API - which wasnt what I needed in the end! Instead I needed to be interfacing the GreenHopper restful API. This resolved all of my issues. Heres a few examples that might help:
List of Sprints from RapidView Board
curl -D- -u username:password -X GET -H "Content-Type: application/json" "https://myjira.atlassian.net/rest/greenhopper/1.0/sprints/<rapid_board_id>"
Long Sprint Summary
curl -D- -u username:password -X GET -H "Content-Type: application/json" "https://myjira.atlassian.net/rest/greenhopper/1.0/rapid/charts/sprintreport?rapidViewId=<rapid_board_id>&sprintId=<sprint_id>"
Short Sprint Summary for points
curl -D- -u username:password -X GET -H "Content-Type: application/json" "https://myjira.atlassian.net/rest/greenhopper/1.0/sprint/complete/model?rapidViewId=<rapid_board_id>&sprintId=<sprint_id>"
There are a number of others. Once I realised that the front-end UI of JIRA OnDemand was using the restful APIs I was after I payed special attention to the url as I browsed around my account and was able to use most of them in the application I built.
The documentation doesnt really reference GreenHopper anymore - Im wondering if they are absorbing it into the core?
Hope that helps!
Joakim Söderberg February 6, 2017
Note that if you are logging in via a sync Google account, it is NOT the google password you are supposed to use. Also it is not the email.
Instead you should go to your user profile and look up your username and set a password.
https://confluence.atlassian.com/cloud/manage-your-profile-and-password-744721602.html
For site admin functions, RSS feeds, REST API access, or WebDAV uploads you'll need to have an Atlassian Cloud password (separate to your Google Apps password. If you haven't set an Atlassian Cloud password, go to the login page and choose Unable to access your account? in the Atlassian Cloud login section.
Of course it makes no sense that this information is not available on the REST API documentation page, since it is quite crucial to get it working.
Deleted user October 17, 2013
We are experiencing the same issue here. I was wondering if Michael's response fixed your issue, OharaSi, or if you found a different resolution. Thanks!
Hey Leslie - I've posted my answer - which is how I resolved it in the end.
Deleted user June 17, 2013
This might a little late, but if you're still having this problem can you show what the actual details that come back are? Is it a 'Forbidden' html page? Also, when you successfully login through the browser is it allowing normal login or do you need to solve a captcha?
Michael Knight
March 5, 2013
The URL is a little bit off. You don't need the /jira part, so it should be
https://<example>.atlassian.net/rest/api/2/project
Otherwise it looks like it should work.
Thanks for your answer Michael, however I get the same response. Its got to be some configuration setting for my user account - we haven't set up a consumer key for OAuth yet - but assumed the basic auth for http wouldnt need it. Also, the documentation at http://docs.atlassian.com/jira/REST/latest/ uses the /jira in all of the examples at the bottom.
Here is the headers from the response using the command $ curl -D- -u uname:pword -X GET -H "Content-Type: application/json"https://myjira.atlassian.net/rest/api/2/project
HTTP/1.1 401 Unauthorized
Server: nginx
Date: Wed, 06 Mar 2013 08:58:57 GMT
Content-Type: text/html;charset=UTF-8
Transfer-Encoding: chunked
Connection: keep-alive
X-AREQUESTID: 538x238122x1
Set-Cookie: JSESSIONID=D02A638EE72BA51844F7B104D6AD3C54; Path=/; HttpOnly
Set-Cookie: studio.crowd.tokenkey=""; Domain=.myjira.atlassian.net; Expires=Thu, 01-Jan-1970 00:00:10 GMT; Path=/; HttpOnly
X-Seraph-LoginReason: OUT
Set-Cookie: studio.crowd.tokenkey=""; Domain=. myjira.atlassian.net; Expires=Thu, 01-Jan-1970 00:00:10 GMT; Path=/; HttpOnly
X-Seraph-LoginReason: AUTHENTICATED_FAILED
WWW-Authenticate: OAuth realm="https%3A%2F%2Fmyjira.atlassian.net"
X-Content-Type-Options: nosniff
Vary: Accept-Encoding
The problem seems to be with the user account I'm using so will try with others. I also noted in the header response that there is an empty value for the studio.crowd.tokenkey in the cookie that is delivered (4 times for some reason).
Michael Knight
March 6, 2013
Do you happen to use Google Apps authentication with your OnDemand instance? If so, you will need to use your OnDemand password (not your Google Apps password) to authenticate.
OnDemand will have prompted you to set an OnDemand password when you first logged in with Google Apps. If you have forgotten it, you can have an administrator set a password for you.
Hans Pikkemaat June 15, 2017
If I remember correctly, if you get the header
This means you activate a protection system because of too many failed logins.
If this happens you would get a captcha in the web interface. But the REST api clearly cannot support this.
I can also successfully log in with uname:pword through the browser.
Just for Atlassians reference - it would be handy if the online support were a little more user friendly - this example from github is straight to the point, sets expectation and walks you through the process easily: https://help.github.com/articles/generating-ssh-keys
Also left this as feedback through ondemand
