JIRA REST API returns HTTP error code : 404
shital chande August 22, 2019
Hi, I'm trying to use the JIRA rest API to get the issue is moved on one status to another, however, for all queries that I tried it returns 404 status.
An example http://localhost:8080/rest/attach-cat/1.0/attachments/get?issueKey=" +issue, however, it returns 404.
And Jira is 7.13.0
Tomas Gustavsson
August 22, 2019
URI structure
http://host:port/context/rest/api-name/api-version/resource-name
https://jira.atlassian.com/rest/api/latest/issue/JRA-9
Please check
https://developer.atlassian.com/server/jira/platform/rest-apis/
Hi Tomas Gustavsson,
  Actually, I am using Smart attachment plugin 2.3.0 version and I am updating Meta Validation Plugin and that using URI http://localhost:8080/rest/attach-cat/1.0/attachments/get?issueKey=" +issue  for getting the issue id's, however, it returns HTTP Failed Error Code is 404. then how to solve this error?
Like • sara hanfi likes this
shital chande September 7, 2019
Thank you,
Tomas Gustavsson,
, for replying me. and now following link is working:
String urlCAL="http://192.168.1.236:8082/rest/api/2/attachment/"+issue;
but still, the same error has occurred. can you tell me please what can i change for following code to give me a list of attached files ?:
try
String authString = "vpsvalidator:8c5ydjGL0S8ZiZsODG2JetNqn";
String authStringEnc = Base64.getEncoder().encodeToString(authString.getBytes("utf-8"));
URL url = new URL(urlCAL);
HttpURLConnection conn = (HttpURLConnection) url.openConnection();
conn.setRequestMethod("GET");
conn.setRequestProperty("Accept", "application/json");
conn.setRequestProperty("Authorization", "Basic " + authStringEnc);
if (conn.getResponseCode() != 200)
throw new RuntimeException("Failed : HTTP error code : "+ conn.getResponseCode());
BufferedReader br = new BufferedReader(new InputStreamReader((conn.getInputStream())));
String output = org.apache.commons.io.IOUtils.toString(br);
Pattern folderpattern = Pattern.compile("\"id\":(.+?),\"name\":\"(.+?)\",\"attachments\":(.+?)]") ;
Matcher foldermatch = folderpattern.matcher(output);
message1 = message1+ output;
while(foldermatch.find())
String attachmentsID = foldermatch.group(1);
String attachmentsFolders = foldermatch.group(2);
String attachmentsDetails = foldermatch.group(3);
if(attachmentsFolders.contains(requiredValue))
String folderFiles1 =attachmentsDetails.replace("{","");
String folderFiles2 =folderFiles1.replace("[","");
String folderFiles3 =folderFiles2.replaceAll("\"","");
folderFiles =folderFiles3.replace("ids:","");
message1= message1+folderFiles;
catch (Exception e)
e.printStackTrace();
throw new InvalidInputException(e+"Unable to Find the Selected folder"+message1+"---"+folderFiles+"==="+requiredValue);
Tomas Gustavsson
September 9, 2019
To get the Attachments, you need to have the attachments id. ex like below.
https://jira/rest/api/2/attachment/139053
so first you need to find the issue and see if i holds any attachments, and then get the attachments Id, then you can use that to request it.
some more info here
https://community.atlassian.com/t5/Jira-questions/How-to-retrieve-an-issue-attachments-with-the-rest-api/qaq-p/572084
shital chande September 9, 2019
Thanks, Tomas for understanding my concept and I want to use the GET method to find the issue and see if I hold any attachments, and then get the attachments Id then what I need to do change the below code :
br = new BufferedReader(new InputStreamReader(conn.getInputStream()));
message1 = message1+ org.apache.commons.io.IOUtils.toString(br);
folderpattern = Pattern.compile("\"id\":(.+?),\"name\":\"(.+?)\",\"attachments\":(.+?)]");
Matcher foldermatch = folderpattern.matcher(message1);
catch (Exception e)
throw new InvalidInputException(e+"--Unable to Find the Selected folder");
can you suggest to me?
