JIRA Server 7.4 Database SQL queries examples
Peter Cselotei - Lupus Consulting Zrt.
Hi All,
I'm searching for the tables what contains the connection between the components and issues at version JIRAServer 7.4.
(The be honest, any SQL example can help, due I have to create several queries)
I've found a documentation like this: https://confluence.atlassian.com/display/JIRA041/Logging+JIRA+SQL+Queries
which is very helpful but it was 3 major versions ago. The new documentations do not cover this topics and the topology have changed already.
I've only found the DB Schema, but it doesn't help due I do not see any connection points (only the component-project part)
Thanks for any help!
Best: Peter
Nic Brough -Adaptavist-
July 7, 2017
Components are tied to issues via the nodeassociation table.  I can't remember the exact definition of the table (and it might vary by version a bit), but there's a source_node_id and sink_node_id field, one is the issue, the other component id, and then there's a sink_node_entity which defines what type of association it is - I think it's still "component" for components
So something like
select * from nodeassociation where sink_node_entity = 'component' and source_node_id = issue_id
should give you components for a specific issue
Thank you!
