I am running JIRA Server on Windows with no additional IIS or Apache, standard install running as a service. I am not following the other posts in community or through the links below to configure http://jira.domain.com - any guidance is post appreciated:
https://confluence.atlassian.com/adminjiraserver071/configuring-the-base-url-802593107.html
Thank you!
Yes, I am not sure how to update the server.xml and/or the Base URL in admin to get http://jira.domain.com to lead me to the application after adding the DNS entry for the same on our network. I will then be working on SSL
Pat, what exactly are looking for? Are you saying that you cannot figure out how to configure JIRA to run on a domain name other than http://localhost:8080?
Have you already registered a domain name and you are wanting to run your JIRA on that URL?
Added:
Pat, to get JIRA running over http://jira.domain.com, you'll need to introduce a Webserver. Install Apache on the server that the DNS points to(doesn't have to be Apache, just the one I am most familiar with). You'll want to follow the steps outlined in the Atlassian documentation:
https://confluence.atlassian.com/jira064/integrating-jira-with-apache-720411718.html
In particular, you'll want to load the correct modules in apache
LoadModule proxy_module modules/mod_proxy.so
LoadModule proxy_connect_module modules/mod_proxy_connect.so
LoadModule proxy_http_module modules/mod_proxy_http.so
And create a new virtualhost that contains something similar to the following:
# JIRA Proxy Configuration:
<Proxy *>
Require all granted
</Proxy>
ProxyRequests Off
ProxyPreserveHost On
ProxyPass / http://jiraserver:8080/
ProxyPassReverse / http://jiraserver:8080/
Thanks for the information!
I will work on Apache install but wish I could remember how it was setup below because I did not have Apache installed before but had the custom url w/o port
Thanks again
Do the proxy statements need to be in certain spot of server xml?
I am still struggling with getting http://jira.domain.com w/o having to use http://jira.domain.com:8080
You should be able to place it at the bottom of the "Virtualhost" section. If you are having trouble you can include conf file for more recommendations.
Kain,
Thank you for your help. I am really at a loss - I don't follow the steps completely on any of the link you included. I updated the httpd.conf and thought I should shutdown and restart before putting in file in place and now can't restart Apache. Included are server.xml and httpd.conf - any suggestions are much appreciated:
<?xml version="1.0" encoding="utf-8"?>
Atlassian JIRA Standalone Edition Tomcat Configuration.
See the following for more information
http://confluence.atlassian.com/display/JIRA/Configuring+JIRA+Standalone
Licensed to the Apache Software Foundation (ASF) under one or more
contributor license agreements. See the NOTICE file distributed with
this work for additional information regarding copyright ownership.
The ASF licenses this file to You under the Apache License, Version 2.0
(the "License"); you may not use this file except in compliance with
the License. You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
<Server port="8005" shutdown="SHUTDOWN">
<Listener className="org.apache.catalina.startup.VersionLoggerListener" />
<!-- Security listener. Documentation at /docs/config/listeners.html
<Listener className="org.apache.catalina.security.SecurityListener" />
<!--APR library loader. Documentation at /docs/apr.html -->
<Listener className="org.apache.catalina.core.AprLifecycleListener" SSLEngine="on" />
<!-- Prevent memory leaks due to use of particular java/javax APIs-->
<Listener className="org.apache.catalina.core.JreMemoryLeakPreventionListener" />
<Listener className="org.apache.catalina.mbeans.GlobalResourcesLifecycleListener" />
<Listener className="org.apache.catalina.core.ThreadLocalLeakPreventionListener" />
<!-- Global JNDI resources
Documentation at /docs/jndi-resources-howto.html
<!-- A "Service" is a collection of one or more "Connectors" that share
a single "Container" Note: A "Service" is not itself a "Container",
so you may not define subcomponents such as "Valves" at this level.
Documentation at /docs/config/service.html
<Service name="Catalina">
<!-- Apache Proxy Connector -->
<Connector
port="8080"
proxyPort="80"
maxThreads="150"
minSpareThreads="25"
connectionTimeout="20000"
enableLookups="false"
maxHttpHeaderSize="8192"
protocol="HTTP/1.1"
useBodyEncodingForURI="true"
redirectPort="8443"
acceptCount="100"
disableUploadTimeout="true"
proxyName="jiratest.msudenver.edu" />
<Connector port="8080"
maxThreads="150"
protocol="HTTP/1.1"
redirectPort="8443"
acceptCount="100"
disableUploadTimeout="true"/>
To run JIRA via HTTPS:
* Uncomment the Connector below
* Execute:
%JAVA_HOME%\bin\keytool -genkey -alias tomcat -keyalg RSA (Windows)
$JAVA_HOME/bin/keytool -genkey -alias tomcat -keyalg RSA (Unix)
with a password value of "changeit" for both the certificate and the keystore itself.
* If you are on JDK1.3 or earlier, download and install JSSE 1.0.2 or later, and put the JAR files into
"$JAVA_HOME/jre/lib/ext"
* Restart and visit https://localhost:8443/
For more info, see :
http://confluence.atlassian.com/display/JIRA/Running+JIRA+over+SSL+or+HTTPS
and
http://tomcat.apache.org/tomcat-6.0-doc/ssl-howto.html
<Connector port="8443" protocol="org.apache.coyote.http11.Http11Protocol"
maxHttpHeaderSize="8192" SSLEnabled="true"
maxThreads="150" minSpareThreads="25"
enableLookups="false" disableUploadTimeout="true"
acceptCount="100" scheme="https" secure="true"
clientAuth="false" sslProtocol="TLS" useBodyEncodingForURI="true"/>
If you have Apache AJP Connector (mod_ajp) as a proxy in front of JIRA you should uncomment the following connector configuration line
<Connector port="8009" URIEncoding="UTF-8" enableLookups="false" protocol="AJP/1.3" />
See the following for more information :
http://confluence.atlassian.com/display/JIRA/Configuring+Apache+Reverse+Proxy+Using+the+AJP+Protocol
<!-- <Connector port="8009" URIEncoding="UTF-8" enableLookups="false" protocol="AJP/1.3" /> -->
<!-- <Connector proxyName="jiratest.msudenver.edu" proxyPort="8080" enableLookups="false" protocol="AJP/1.3" URIEncoding="UTF-8"/> -->
<Engine name="Catalina" defaultHost="localhost">
<Host name="localhost" appBase="webapps" unpackWARs="true" autoDeploy="true">
<Context path="" docBase="${catalina.home}/atlassian-jira" reloadable="false" useHttpOnly="true">
Note, you no longer configure your database driver or connection parameters here.
These are configured through the UI during application setup.
<Resource name="UserTransaction" auth="Container" type="javax.transaction.UserTransaction"
factory="org.objectweb.jotm.UserTransactionFactory" jotm.timeout="60"/>
<Manager pathname=""/>
</Context>
</Host>
Access Logging.
This should produce access_log.<date> files in the 'logs' directory.
The output access log lies has the following fields :
IP Request_Id User Timestamp "HTTP_Method URL Protocol_Version" HTTP_Status_Code ResponseSize_in_Bytes RequestTime_In_Millis Referer User_Agent ASESSIONID
eg :
192.168.3.238 1243466536012x12x1 admin [28/May/2009:09:22:17 +1000] "GET /jira/secure/admin/jira/IndexProgress.jspa?taskId=1 HTTP/1.1" 200 24267 1070 "http://carltondraught.sydney.atlassian.com:8090/jira/secure/admin/jira/IndexAdmin.jspa" "Mozilla/5.0 (X11; U; Linux x86_64; en-US; rv:1.9.0.10) Gecko/2009042523 Ubuntu/9.04 (jaunty) Firefox/3.0.10" "C2C99B632EE0F41E90F8EF7A201F6A78"
NOTES:
The RequestId is a millis_since_epoch plus request number plus number of concurrent users
The Request time is in milliseconds
The ASESSIONID is an hash of the JSESSIONID and hence is safe to publish within logs. A session cannot be reconstructed from it.
See http://tomcat.apache.org/tomcat-6.0-doc/config/valve.html for more information on Tomcat Access Log Valves
<Valve className="org.apache.catalina.valves.AccessLogValve"
pattern="%a %{jira.request.id}r %{jira.request.username}r %t "%m %U%q %H" %s %b %D "%{Referer}i" "%{User-Agent}i" "%{jira.request.assession.id}r""/>
</Engine>
</Service>
</Server>
does not seem to want the httpd.conf - only made sure three LoadModule lines are uncommented
Try including them as an attachment instead of pasting into the comment box.
