JIRA Software is licensed but not currently installed.
Tobias Ednersson November 17, 2016
After installing JIRA software 7.2.5 and migrating a JIRA cloud application,
I see under Versions and licenses That "JIRA software is licensed but not currently installed"
I tried to download and upgrade the system, but that did not help. I also see that I still have the software plugin installed along with some other plugins that i suppose are now a part of JIRA software. How can i install JIRA software on top of an excisting JIRA core installation?
Tobias Ednersson December 19, 2016
Apearantly 7.2.5 was unstable so I downgraded to JIRA 7.2.4
Nic Brough -Adaptavist-
November 17, 2016
Go to admin -> manage applications, there should be an option to install Software from there.
VernonJ
November 23, 2016
I am having the same trouble, but the link to install it from there leads to the same install file I just used. In fact, it leads to 1 version less: 7.2.4 and 7.2.5 doesn't seem to be available. Regardless, 7.2.5 was a jira-software installer.
Henrik Gerdtsson December 19, 2016
I just installed 7.2.6. Actually I did it several times to get it right. The first time JIRA Software was installed, but later with the same installation file only JIRA Core was installed. I even tried to just do an update of the current installation. Still only JIRA Core is installed. From the installation log it seems like JIRA Software was installed.
The file I use is atlassian-jira-software-7.2.6-x64.bin downloaded from your server 15 December.
I tried to downgrade to 7.2.4. JIRA would not start due to version mismatch in the database. I then upgraded from 7.2.4 to 7.2.6. Unfortunately it did not help. I still only have JIRA Core installed.
VernonJ
December 19, 2016
The solution I got from Atlassian support was to install the 'software' portion from a separate file, as the version in the packages was corrupt or damaged.
The side-loadable file is type 'obr', and the 7.2.4. 'software' .obr file works with 7.2.5 'core'. The .obr file can be loaded from the 'Applications' page. the file can be downloaded from here: https://marketplace.atlassian.com/plugins/com.atlassian.jira.jira-software-application/versions
The full workaround I used to successfully get my system running is here: https://jira.atlassian.com/browse/JSW-15235
But more or less the fix is to replace the .obr file from the 7.2.5 package with the one from 7.2.4. I  installed 7.2.5 and installed the 'JIRA software' portion from the 'applications' page, using the downloaded .obr file. If you run into trouble with the upload, try a different browser; I've had some issues with uploads using IE.
Like • gani mahdi likes this
I found my problem. I am in progress of migrating from an old server. In that process I copied the old jira_home to the new server. I did this after starting JIRA. That removed all the installed plugins from 7.2.6. I clean install and controlled migration of data from old jira_home did the trick.
