×I know there are questions already answered but I can't get it to work.
I want to grant an external user access to a specific project, without having to change permissions for all other projects.
I created a new group, added this user to this specific group and removed it from the "jira-users-group", and added this user to the project.
But when I log in as this user, I can't access any project.
What can I do from there?
Hi Nathan,
Let's assume that you want to give Bob access only to project ABCD and nothing else. I'm afraid there's no simple way to do this without changing the permissions for other projects as well.
Please find below the step-by-step guide. Mainly you will have to create 2 new groups, let's say Internal and External. Add Bob only to the group External and every other user to the group Internal. Then create a new permission scheme that grants permissions to both groups, and modify the Default Software Scheme to remove access given to Any logged in User and provide access only to Internal group. The procedure might seem long, but this is because I have described every step in great detail. The whole thing should take about 30 minutes.
Part 1: Create the 2 groups:
Part 2: Give application access to the group External:
Part 3: Assign all the other users to the group Internal and assign Bob's user to the group External:
Part 4: Modify the current permission scheme to remove access for any logged-in user and replace that with the group Internal.
Part 5: Create a new permission scheme based on the default one, modify it to include access for group External and assign it to the project ABCD:
Part 6: Assign the new permission scheme to the project ABCD:
That's it.
thanks. there is no way I would have figured that out myself.
A few changes:
- in part 4 section 3, do the grant of the group internal before removing the any logged in user. it is easier to see where you are in the long list.
- in part 5,section 4 the group is external, not abcd, and it is easier to say add the group to where ever you see the internal group
And, there should be an easier way than to spend lots of time doing all theses steps.
Whoa @Claudiu Lionte this is exactly what I was looking for! I'm sure many others would appreciate the time and attention to detail you put into this step-by-step guide. Thank you so much for doing that.
It'd be great if your steps were just added to the JIRA official documentation. I know there are lots of repeat questions with the same ask (I just submitted one a few days ago...and only found your answer now).
@Nathan Zylbersztejn Did you get the project restrictions to work like you needed? If so, it'd be great for you to "Accept" Claudiu's answer so that it'll be ranked higher in future related searches 👍🏼
@Claudiu Lionte Quick question: Is there a reason why you're shying away from granting the Browse Projects permission to Roles, instead of the 2 specific groups?
I imagine that'd make future project admin easier too, but curious to hear your thoughts.
Hi @Johnson Wang,
There is no technical reason for me to recommend groups over project roles. In fact, it is, indeed, best-practice to use project roles instead of user groups.
The reason why I created this procedure using groups instead of roles is simplicity, as project roles will add a separate level of complexity and, especially for admins new to Jira, might create more confusion.
@Bob_Gifford Thank you, I will edit my answer to correct the small mistakes that you spotted.
Very helpful. Thanks for posting this answer.
@Claudiu Lionte Umm.. I think i still have an issue.. Still external user can see all my other projects, any help would be appreciated on this please?
They are being allowed in with the permission scheme. You need to look at the permission schemes to see if they belong to ANY group that is getting permission. As I I and others have stated, by default JIRA puts the jira-users group access (depending on release the group may have a different name). The best way to control access is to remove ALL groups from the permission scheme and use project roles. The project admin controls membership in the roles so there won't be any surprises in accessing the project. By using roles you can have one permission scheme for all projects.
Thanks @Joe Pitt & @Claudiu Lionte, probably I will try again to follow all steps, not sure where I am making mistakes. but anyway this was very useful. I will try again and see where I missed..
Thanks for the support. It helped me a lot but it is not 100% correct.
Part 5, Section 4 should be done only for specific access only otherwise client will get access to every feature in your project.
I have written a separate article on how to give a user permission to only one project:
This new approach uses project roles instead of groups and is considered best-practice (as Johnson noticed). It is just a bit more difficult to implement initially, but it has the advantage that it scales well and once implemented you can easily add another person to a separate project.
The most common scenario for this is when you want to give access to your customers to their projects, and one customer must only see their own project.
Doesn't this require any change to Application level group permission (by default include only jira-users) ?
I asked that because even after I add a (external) user to client group, he/she still has to be in jira-users, hence by default will see all existing projects that have jira-users in the User role (which is included by default)
The instruction is really helpful. Thanks for doing that. I still have some questions:
1- Why do we have to create Internal group? Can't we just use jira-users as Internal group, take Bob out of this group, and add him to External group, does it suffice?
2- If we give External group access to JIRA App, but in the project that we want Bob to access, we just grant Bob's account directly into the special permission scheme for that project, I guess that it still works (even though I know it's a maintenance issue to track individual accounts in the permission scheme, but technically it should work). Is that correct?
The basic problem with using the jira-users group in any permission scheme is it is ever changing. Whenever a user gets an id they are automatically added to all groups that have logon rights. The best way to get control over who can access what is to use project roles. It gives the best granularity and allows project admins to allow only those users to have access that should. It is the standard best practice security model. Since all project roles are universal and appear in all projects one permission scheme can be used across all projects.
Hi Joe, You are totally right with the project roles argument here. So no question about it.
The question #1 here is just for Part 1 of the instruction above, to understand better the need to replace default jira-users (where all users are in) by Internal group. I hope that I don't need to create Internal group, and just use jira-users for all users except Bob. It will simplify the changes we need to make to all the permission schemes which used jira-users group before.
You don't want to create an internal group. You want to stop using groups in permission schemes and convert to project roles. You can add the project roles and convert over a period of weeks project by project. JIRA admins need to administer groups. Project admins add/delete users from project roles.
You are right again. Sorry, for the confusion.
I don't use group in permission schemes, but I have to grant jira-users group the Users Project role (and/or other roles) for every project in the Project configurations, (not in the permission scheme).
Let me rephrase my question by rewriting the instruction above by a simpler steps here and hope that someone would tell me if it still works, or not:
Part 1: Create the 1 new group called External:
Part 3: Assign Bob's user to the group External:, and take Bob out of jira-users group
Part 4: Add Bob to the appropriate Project Roles of the only project, AAA, which he needs access
Assuming that all the projects are currently working as expected prior to Part 1. Then can I use the instruction above to just give Bob access?
And if there additional users like Bob in the future, I can just following Part 3 and Part 4 for them. Does it work?
I think I missed the first step to ensure NO permission scheme allow 'any logged in user'. This must be made, before my steps above hold:
Part 0: Modify the current permission scheme to remove access for any logged-in user and replace that with the group jira-users.
I think the cloud is setup a differently than the server version. The jira-users group contains all the users so by granting it access you grant everyone access. The point I'm trying to make is to stop using any group allowing login access from permission schemes. The cloud may work differently, but any time a user is added they are automatically added to all groups, except admin, that allows login access. Almost anyone using groups in permission schemes will eventually have a problem restricting access.
JIRA works by GRANTING access. You can't restrict access. By default it grants access to the group used to logon (used to be jira-users but may be different on your version). This is probably where you're getting the access from.
The FIRST thing you need to do to get control is to remove any groups with logon privileges from the permission scheme unless you absolutely want everyone to have that permission. Then I suggest you setup user roles for the various functions like, tester, QA, Browse Only, etc. Then you can create one permission scheme to cover almost all projects. The project admin controls which users are put in the roles. This may be a big effort, but it will payoff down the road by making it easy to control access.
You need to configure the permission scheme for the project you want the user to access. Take a look at Permissions overview, it explains how the different permissions and how a user is assigned to them.
Thank you Mikael. The link explains concepts but not how to do the simple thing i need.
I created a new permission scheme, added this project to the permissions scheme and removed it from the default one. Created a group, add an external user to this group, and added browse and manage project permissions for that group to the scheme
When I log in as this user, I can see all projects but the one he's supposed to have access to... What am I missing?
Ni Nathan,
If you need more help on this, I've created a new KB with a step-by-step in the New Interface of Jira Cloud to better illustrate them, so I'd recommend you to check it out!
Please, let me know what you think!
Cheers
Learn more
