JIRA Styling Language
Jessica Romero
December 2, 2024 edited
Hi there!
I'm hoping to customize some of my custom fields that contain the Wiki Rendering. Does anyone know of a reference guide for the markup used?
I'd like to add things like "Notes" or "Info" fields using the create workflow automation.
December 2, 2024
Hi @Jessica Romero
This is the formatting documentation for such fields: https://jira.atlassian.com/secure/WikiRendererHelpAction.jspa?section=all
Please note many of the macros for fields like Description are not directly available.  Instead, I believe one must call the REST API endpoints and use the Atlassian Document Format (ADF) to use such macros.
Jessica Romero
Thank you @Bill Sheboy ! This is exactly what I was looking for!
Like • Bill Sheboy likes this
Nikola Perisic
Hello @Jessica Romero
You can change your custom field to be wiki style rendered using the field configuration scheme, but your field needs to be the text type.
Jessica Romero
Yes, those are all setup accordingly. I'm looking for the markup language guide so I can pre-populate them with markup text.
atlassian, confluence, loom, atlassian intelligence, ai notes, ai-powered meeting notes, atlassian community events, ace, confluence ai, loom ai integration, ai note-taking, atlassian ai features, team '25, atlassian live learning, confluence automation
Unlock AI-powered meeting notes: Join our live learning session! 📹
Did you catch the news at Team ‘25? With Loom, Confluence, Atlassian Intelligence, & even Jira 👀, you won’t have to worry about taking meeting notes again… unless you want to. Join us to explore the beta & discover a new way to boost meeting productivity.
Register today!
