I'm trying to use the "JIRA Suite Utilities" plug in so I can set a Custom Field value during a workflow transition - But the plugin is disabled and I can't re-enable it.
Please advise how I can switch it on,
Thanks for your assistance.
Be default "JIRA Suite Utilities" is disabled on JIRA cloud. You should contact support and request to enable it: https://support.atlassian.com/servicedesk/customer/portal/23
Cheers - I'm not really clear why I need to email support rather than click a handy button, but sure, it's working now. Thanks.
