Hi Team,
We have JIRA server 8.20.12 and BAMBOO server 8.0.5 verison currently running, now we need to change the Java version to "Oracle Java 8u381", I had tried to refer official document but no luck, could you please confimr on this compatibility.
Thank you,
Dev G
I found these two documents. Unless I'm reading them wrong, you should be OK on versions.
But I would want you to make that call yourself. :)
Hope that helps.
Thank you so much for the reply @Dan Breyen
Hi @Dan Breyen ,
I have chekced in the above shared links,
JIRA : - we have JIRA 8.2012, it is compatible with the ORacle JDK 8 as per the document. But in the bundled JRE it shows only "Adoptium OpenJDK 11.0.13+8" and Tetsed JRE as blank. Is this means, Oracle Java 8u381 can be supported to JIRA 8.20.12 version an slaos withh BAMBOO 8.0?
Can we proceed on the patching activity?please confirm and also refer below screen shot fr more clarifications.
Please confirm on this compatibility asasp, we need to plan patch on high prior.
Thank you in advance,
Dev G
Hi Dev, I would suggest contacting support (support.atlassian.com/contact) for a definitive answer.
Help us plant more trees
