JIRA jira.i18n.title ignored by workflow
Jeanne Howe
January 11, 2016
I am trying to change the title on one of our workflow transitions buttons using the jira.i18n.title property. The workflow is ignoring the property and my button is not being renamed. Have I configured it incorrectly? Are there additional properties I need to set? Here is what I have configured on the transition:
Property KeyProperty Value
jira.i18n.titletodo.title
3 votes
Steven F Behnke
January 11, 2016
Instructions from the associated JIRA issue
https://jira.atlassian.com/browse/JRA-6798?focusedCommentId=58521&page=com.atlassian.jira.plugin.system.issuetabpanels:comment-tabpanel#comment-58521
  1. Open the jar file atlassian-jira/WEB-INF/lib/language_<language code>_<country code>.jar
  2. In that jar edit the file \com\atlassian\jira\web\action\JiraWebActionSupport_<language code>_<country code>.properties
  3. Add the translation to the file, for example:
    provideinfo.title = This is a test translation
  4. Make sure you remember the key you used. Save the file.
  5. Restart Jira
  6. Goto your workflow in Jira (Administration -> Global Settings -> Workflow)
  7. Click on the transition you would like to translate
  8. Click on View properties of this transition
  9. Add the property:
    • Key = jira.i18n.title
    • Value = <key of the translation>
  10. Activate the workflow
  11. Repeat steps for each transition and language
Andy Heinzer
August 16, 2017
I believe that Steven's response was accurate at the time in 2016.
With JIRA 7.3 and higher, the location of this plugin is no longer under the installation folder.  Instead this exists now in the [JIRAHOME]/plugins/installed-plugins/ folder.
Also the properties file could be in a slightly different path of that .jar file now.  For example in the JIRA 7.4.x version this file exists in the path of /com/pyxis/greenhopper/jira/actions/BoardAction_de_DE.properties for the German translation.
But otherwise I was able to follow the rest of the instructions.  I saved this file back to the folder, zip the contents, rename this to a .jar, replace the translation jar, and restart JIRA to make this work in JIRA 7.3/7.4 versions
Like • 2 people like this
Steven F Behnke
August 16, 2017
Chander Inguva
January 11, 2016
Sure,
           Do the following, edit the workflow
Select the transition you want to update and click on edit next to Delete transition from above figure
  • Update the transition name and click Save
Regards
Chander
Adam Dulberg
I have a solution for those on CLOUD and using Service Desk (or applies to any project I suppose). Originally I copied the Jira Default Workflow, and same as everyone here, found no matter what I did, "START PROGRESS" was the transition [button] from Status A to Status B (where Status A is the first status after your create transition).
Looking at properties on that transition you see this:
Simply delete jira.i18n.title that contains startprogress.title, and problem resolved. From there you should only see the name of your transition. The directions above are for hosted Jira and not cloud.
Cheers Cloud folks.
James Rogers
May 24, 2018
Prop Key                    Prop Value
jira.i18n.submit   sd.workflow.itsupport.v2.transition.resolve.this.issue.submit
Jeanne Howe
January 11, 2016
Perhaps I am not explaining my self. I have a transition that I have named Return to To Do. I need to leave the name of the transition as-is, but I want the button to say To Do (not Return to To Do). I should be able to do this using the transition property jira.i18n.title.
After adding the property to the transition, the button name is not changed as expected.
Steven F Behnke
January 11, 2016
I'll try to explain how to use the properties in a new Answer. Can you explore the concept you're trying to achieve? I'm just trying to make sure I understand.
Michael Marley
January 11, 2017
I am having this same issue.  Adding a jira.i18n.title key to a transition does nothing in my Core 7.3.0 install. Is this a known bug that is not being fixed?
Teja
December 3, 2017
Hi Jeanne Howe,
Did you get solution for this?
I also have the same requirement.
Jeanne Howe
December 4, 2017
Teju,
The only solution found was that from Steven Behnke (listed at the top).
Please note that with newer versions of JIRA, the file location has changed to <baseURL>/application-data/jira/plugins/installed-plugins
Jeanne
Steven F Behnke
January 11, 2016
I would follow Chander's steps; using Properties is for translating workflow objects like transitions, not for changing the core name.
Chander Inguva
January 11, 2016
Hi Jeanne,
To rename the workflow, please make the workflow inactive by unassigning it from associated workflow scheme and then rename and then add it back to workflow scheme.
Regards
Chander
Jeanne Howe
January 11, 2016
Chander, I do not want to rename the workflow, I want to rename one of the workflow buttons.
Register today
